heated rear screen test
SGP
Is it possible to check the heating grid on a rear screen prior to fitting ? I have a choice of 2, and want to fit the best one. As far as I know one of them has a couple of dead elements. Thanks in advance.
If it ain't broke..
Fix it till it is
Fix it till it is
Connect up the power and mist it up.
A bit more scientific way is to connect twelve volts across it, and check that there is six volts on every track in the middle, but be careful not to cause damage with the meter probe.
SGP
Thanks Brian.
If it ain't broke..
Fix it till it is
Fix it till it is
