Wipers and washers technical help?
bigwinn
Post Sun Jan 22, 2012 8:04 pm
My wash/wipe has developed a life of its own- activating with no input from the stalk, for long times too which is annoying
Whats the cause? is it the relay?
TIA
Stu
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
DHFiS
Post Sun Jan 22, 2012 8:16 pm
My wipers came on randomly when a spare fuse came loose in the fuse box and slid under a relay
bigwinn
Post Sun Jan 22, 2012 8:17 pm
checked, nothing rattling round in there-
clipper
Post Sun Jan 22, 2012 9:29 pm
Mine does this when the connections on the loom for the heated jets get wet or come loose (the clips on the plugs have seen better days).
A quick clean up of the connectors and it goes away.
Do both the wash AND the wipe activate on their own?
clipper
Post Mon Jan 23, 2012 7:43 am
Brianmoooore wrote:Do both the wash AND the wipe activate on their own?
Sure this question is aimed at the OP, but just in case it helps; in my case the wiring "fault" causes the wash motor to kick in momentarily, but not enough so that I see any water spray out.
This makes the wipers come on, then it happens again and again, giving the impression that the wipers have been "turned on".
Sometimes I noticed a slight pause in the wiper action and this was what alerted me to the fact that it was the wiper system being activated by the wash function.
bigwinn
Post Mon Jan 23, 2012 8:33 am
Yes, at the same time, wipers and washers going
Post Mon Jan 23, 2012 8:50 am
There is a brown/black wire that runs from the column switch, across behind the dash, up into the fusebox to the wiper control module, and then around the front of the car to the washer pump.
If this wire shorts intermittently to earth anywhere along its length, you will get what you describe.
The most likely pace for it to short is in the column switch itself, but it could be anywhere. Any damage to the loom at the front from any front end shunts at any time?
bigwinn
Post Mon Jan 23, 2012 9:09 am
nil as far as I know
I had exactly the same on the bronzit which occurred when I hit an unfeasibly large pot hole
I'll get the column shroud off and have a look
ConvertChris
Post Tue Jan 24, 2012 6:12 pm
Hi,
I have a problem like this, driving 318 con in the rain, wipers on single speed then I notice that my washer are working, fiddle with the stalk switching them on and off but the washer still working, in the end pull over and disconected them, I have since reconected them and it has been fine since!
I also have a problem with my 89 Touring, no washers, I have yet to check the washer motor :mad:
