Any help greatly appreciated
Rear sidelight out
JdmFanBoy
So just recently my rear sidelight stopped working, the bulb didn't look broken but I changed it anyway. It still didn't work, I then tried cleaning the contacts (the metal bars in the light) Still no luck and I've now run out of ideas. Any Idea's what's stopping it from working?
Any problems with any other lights in the cluster ?
Did you change the bulb for a brand new one ?
Have you checked with a multimeter whether there is power getting to the contacts ?
Lots of electrical faults are caused by bad earths and can be traced for free by some wire-wiggling.
JdmFanBoy
All the other lights work fine. The bulb is brand new and I checked with the bulb from the other tail light and that didn't work either. I haven't got a multimeter handy, I've wiggled all the wires but nothing is loose
There are at least three versions of the bulb holder assembly used on facelift E30s. The type which flat pieces of sprung metal about 8-10mm wide for the bulb contacts and where all the internal wiring is hidden is known to have reliability issues, so if this is the type you have, then that could be the problem.
The problem might well be obvious and easy to repair if you open the assembly up, but I've never bothered to try.
JdmFanBoy
So your saying the next step is to buy another assembly?
Remove the lamp assembly from the car, and then remove the socket from the other part of the light, by spreading the two tabs.
Identify the brown and grey/something (you didn't tell us which side or which engine!!!!) and use a couple of bits of wire to connect the pins directly to the bulb. If it lights, then the lamp holder assembly is at fault.
A second hand one off of here shouldn't cost much. The version that looks cheap and nasty, with completely exposed round solid wires making up the connections and lamp holders is the most reliable in my experience.
