Dismantle chrome bumper
How do I remove the black rubber trim from the chrome rear bumper?
Jim320i
- E30 Zone News / COTM Team
Have you removed the bumper already? If not, i'd advise you to do so... Once its off you'll see how its held on. The inside section of the bumpers has little clips holding it in place. I cant remember if you squeeze them or push them, but its quite obvious once you see them...
But remove the bumper to get to them easier for sure.
IIRC its held in place with those metal spring clips - you need to take the bumper off and its obvious then
kam-325i
Squeeze the clips....
Be carefull, they are small and can be a bit brittle.
I see thanks. Its a spare bumper I had laying around.
eire30
if there happened to be a tech1 kit on it originally you won't have the clips it will be bolts (likely well rusted on if mine were anything to go by!)
Rich
Rich
