Just a quick one, on the 325i M20 engine do you have to remove the steering rack to change the sump gasket or can you do it without taking the rack off?
Also, does anyone else suffer from a noisy thrust bearing? I changed the clutch and bearing a little while ago because the original was slipping and also had a noisy bearing. But the new one has started to get noisy as well?
