FOG light help please.
e30kid6
Sat Jan 21, 2012 11:39 am
Mine is the 88' 318i, and when i bought it, it only had the rear fogs and the one button for the fogs.
So i bought some front fog lamps, installed them and plugged them in (because the loom is already there). I then bought a new switch that has the two separate buttons on it for front/rear fogs. But after installing neither of the fog lights work. Is there something im missing?
The connector that the switch connects two has 4 wires coming out of it which i assumed was two for the front and two for the rear.
Any experience of this?
Lee
Grrrmachine
E30 Zone Wiki / Team Member
Sat Jan 21, 2012 11:46 am
Have you installed the right fuses and relay into the Fuse Box?
http://www.e30zone.net/e30zonewiki/index.php/Fuse_Box
e30kid6
Sun Jan 22, 2012 10:05 pm
Thanks i've checked this, placed the fuses in their correct places. Relay is already there and they all work, but yet no fogs with this new switch. :\
TPS
Sun Jan 22, 2012 10:15 pm
Sounds Stupid, have you got bulbs in the Lights? You'll need to put a bulb in the clocks as well.
Sanchez
Sun Jan 22, 2012 10:17 pm
Switches can be dodgy.
Bulbs good?
Contacts in foglight housing good?
Ide use a multimeter and starting at the bulb see if theres 12v. Work back to the switch and see where the 12v disappears.
Sun Jan 22, 2012 10:18 pm
Have you installed the tell tale in the instrument custer? Does it work?
jonny323i
Sun Jan 22, 2012 10:31 pm
with you saying the relay is already there there should be 2 of the black square relays as one already does another job have you got 2 or 1 installed
Touring for life
SimonTemplar
Sun Jan 22, 2012 11:54 pm
I recently fitted fog lights on my Touring, I had to fit the fuses, dash switch etc but the relay was already in place. Don't know why - my car has never previously had fogs - so perhaps some of them came out of the factory with the extra relay already fitted.
ST
Lagoon Green 1993 318i Lux Touring
e30kid6
Mon Jan 23, 2012 9:41 am
The lamps are brand new, so they should be fine.
My fuse box has K2, K3, K4 AND K8 installed. (K8 is black). As far as i'm aware that should be all I need.
I cleaned all connections before I put the lights in, but I best do it again.
I haven't installed anything into the cluster, will that need to be there?
Ill have to get the mulitmeter out tonight then i guess.
Cheers guys
lee
bigwinn
Mon Jan 23, 2012 9:50 am
when you switch the rear fogs on you get an amber tell tale light in the instrument cluster
you need to have a bulb in the adjacent green tell tale to indicate front fogs on too
Stu
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
Mon Jan 23, 2012 6:41 pm
bigwinn wrote:when you switch the rear fogs on you get an amber tell tale light in the instrument cluster
Stu
And if you fit it (A legal requirement, I think), and tell me if it works, it will narrow down considerably where the main fault is.
e30kid6
Tue Jan 24, 2012 11:17 am
okay, thanks ill let you know as soon as i've done it.
