cab horseshoe release handle
Rtaylor2208
Well like many cab owners the handle on mine has broken at the hinge pin is a drivers or passengers side door handle the same?
mrLEE30
Yes but you need to keep the handle part from your horseshoe handle, use a thin screwdriver to push the pin out, then use a door handle also remove the pin, now swap the surrounds around and it's all fixed!
adit
i have handles, surrounds and complete horseshoe release mechanisms available Russell. phone me if i can help
cheers, Adi
cheers, Adi
[quote="bss325i"]
Rtaylor2208
Thanks Adi, will try and give you a bell on Monday.
