My 1988 320i wobbles
H35-24
Post Fri Jan 20, 2012 7:01 pm
I have owned my 320i for just over 3 years. It has always wobbled. But it's getting worse now. It seems to come from the rear axle. Recently it started to have a subtle "duk duk duk" noise from the rear when I pull away from the cerb in the morning. The diff has had a slight wine since I bought the car.
In the begining I could notice the vibration at 55 mph (90 km/h) as the rearview mirror would start to vibrate making the view unclear. If I then held my finger on the mirror I could feel the vibration. Going 62 mph (100 km/h) made the vibration go away only for it to come back very clearly at 75 mph (120 km/h) the car though thankfully has a vibration free sweetspot a 80 mph (130 km/h) which is the legal speedlimit were I live.
I'm considering buying a used diff and then putting together a completely overhauled rearaxle in the attempt to get rid of this wobble.
I manage a fuel consumption of about 30,5 mpg (13 km/l or 7,7 L/100 km) so the brakes are not the problem. (This might seem very high to some, but I get help from a very flat terrain and some long straight country roads were I live).
Anyone got some ideers as to what is the matter with my 320i, or should I just overhaul a rear axle and replace the old one on the car?
Why is there not enough time to do it right, but allways enough time to fix the errors - I borrowed that, just so reallistic in my line of work.
H35-24
Post Fri Jan 20, 2012 7:07 pm
Oh and I should mention I got brand new sommer tires, which the car runs really well on, the wobble is very subtle with these on. But on my winter tires, which are about 1a year old the wobble is more noticeable.
kam-325i
Post Fri Jan 20, 2012 8:18 pm
could be rear sub frame bush's
E30Gheko
Post Sun Jan 22, 2012 9:55 pm
kam-325i wrote:could be rear sub frame bush's
This.
Mine's doing the same, but the duk duk duk is now a rattle rattle rattle...
Fitting new bushes tomorrow. not a job im looking forward to but needs to be done...
H35-24
Post Sun Jan 22, 2012 10:02 pm
My bushes are 1 year old. The car wobbled before and after. So I don't think it's the bushes.
The duk duk duk is distinctivly related to the speed of the car, it dies out when I pass 20 mph, and doesn't reappear until the next morning. (I allways leave my car in gear when I park it).
Post Sun Jan 22, 2012 10:10 pm
I would change the wheel bearings before the Diff, is it on rear drums or discs?
E30Gheko
Post Mon Jan 23, 2012 1:17 pm
ignore me, mine was not the subframe bushes as suspected. On inspection up on the ramps it became clear that it was infact the dampers that were more than just a little worn. :o:
Bummer since I already had a pair of bushes that have been rattling round in the shed for a year or more. On a positive note, considerably easier to replace....
Let us know if you get to the route of the problem. :wink:
H35-24
Post Mon Jan 23, 2012 7:11 pm
It's drums.
I bought the car as said about 3 years ago. I have done all kinds of stuff on it. Front struts have been replace completely, new front suspension bushings, it's got a M technic suspension, and I also replaced the exhaust and gearbox.
But other than changing the rear subframe bushes, springs and adding the anitrollbar I haven't touched the rear axle.
I also replaced the cambelt, waterpump and rockerarms.
The car has done 120.000 miles and I have put the last 45.000 miles on the clock in the 3 years I have owned it.
