I've recently acquired a Blaupunkt Woodstock, the European equivalent of the Memphis SQR88. It looks fairly easy to connect, with the diagram pasted on the cover, so I took out my old radio, and wired it in.
First problem was that it would only switch on, no display, and no power on to ariel. I then found that by supplying a switched +12v to the ariel output, the radio would start up with display, and radio etc would all work. Only problem being that as soon as you switch on the ignition, the ariel would go up. But hey ho, at least it all worked, sounded great, and I'd sort out the ariel another day.
Then I found that the battery was going flat within 2 days. Didn't think much of it, and just recharged battery.
Decided today to look further into it, and now found that radio will not start up
Checked my connections again, and all looks just right. Heres the diagrams followed by my connections. Any ideas whats gone wrong?
Top left
On first (large) terminal Battery ground
On second (large) terminal +12v supplied when ignition switched on only
On third (small) terminal feed for ariel
On fourth (small) terminal a permanent +12 that is always there regardless of whether ignition switched on.
No preamp so nothing in DIN socket
Bottom row 4 speakers
Its only by providing a link between 2nd a 3rd terminal on top row that I got it going in first place, but now think that this is what has caused it to die!??
Any suggestions?? The radio looks superb in the dash, and I want it back alive!
