Currently wiring in megasquirt onto an m20'd car. Im making the wiring loom adapter myself (from megasquirt db37>motronic 55pin) and have a few questions regarding earths.
first off, heres the ECU plug diagram
http://pdf2jpg.net/picture.php?pic_inde ... hod=inline
been following a few topics online which have completed the conversion, particularly this one which says to earth pins 2, 10, 14, 19, 24 and 26 of the ECU loom:
http://farm4.static.flickr.com/3096/259 ... 6bfc_o.png
pins 2, 14 and 24 according to the top diagram, are already earthed pins so I dont need to earth these pins, right?
whats pin 19 about? (earthed, but loops on the wires for the CID, O2 and CPS sensors)
pins 10 (O2 sensor) and 26 (IAT sensor) are the only ones I can see which need earthing? Megasquirt has a dedicated signal earth pin so I can just earth these two to that.
So if pins 2, 14 and 24 are already earthed, can I earth my megasquirt earth's (4 of them) to these pins? Are they chassis or engine earthed? Are they strong enough earths?
Probably asking too much but thought it was worth a punt!
Chris
Electronic Guru's - ECU Plug Pins
CHR1S1990
Anyone got nothing better to do on a friday night like me?
need to know where the pins 2, 14, 19 and 24 are earthed to, and what's with the "loops" on 19? Ideally I want a really heavy earth pin out of these 4 to link to the megasquirt.
another question, I see the TPS doesn't earth back to the ECU. Anyone know where this goes to? Same situation with the blue temp sensor? Ideally i want to run all sensor earths (Blue coolant temp sensor, intake air temp sensor, TPS, O2) back to a dedicated pin on the megasquirt ECU.
