Gear box issue.
Post Thu Jan 19, 2012 12:08 am
Hi all, Iv been having a bit of a problem with my gearbox, when I bought my car a few months ago it felt a little hard to select 1st gear when the car was stated cold but nothing too bad, but the last week or so since it's been freezing over night, when I start the car sometimes I can't even get it in to 1st I have to really bang it into gear, and when driving it can be difficult to select the other gears and grinds some of the time when trying to, when the car warms up after a few miles or so selecting any gear is a lot easier and doesnt grind, my clutch doesn't drag or smell, but I onlyhave to lift of the clutch a few centimetres for the bite, so could it be the gearbox or the clutch that is the problem or both?, thanks
Rtaylor2208
Post Thu Jan 19, 2012 12:14 am
Has the gearbox oil been changed. Really old oil could be the cause. This had been mentioned before in other tech help posts.
sag
Post Thu Jan 19, 2012 12:15 am
Hi there
It sounds like clutch hydraulic problem, check for leaks on the slave and master cylinders ,if okay get the clutch hydraulic system bleed.
sag
Post Thu Jan 19, 2012 12:16 am
Rtaylor2208 wrote:Has the gearbox oil been changed. Really old oil could be the cause. This had been mentioned before in other tech help posts.
Or this
Post Thu Jan 19, 2012 12:20 am
Sounds like both the gearbox oil and the hydraulics to me.
If it's still difficult to get into first after the hydraulics are sorted, then the recognised cure is to use ATF Dextron II in the gearbox, instead of SAE80; the same as used in the E34/36 gearbox.
320
Post Thu Jan 19, 2012 12:21 am
Is it easy enough to change the gearbox oil my self or is it best to take it to a garage, should I check the oil or just do the change anyway as I don't know when or if the fella who had it before had it done, does releasing the clutch pedal a few centimetres for the bite sound ok or is that something I should look at as well, thanks guys
