My rear heater blower does not work, I just get smoke coming out if I leave it on?
Any suggestions? Is it easy enough to replace?
I have looked at removing the back seat to take a look but for the life of me cannot figure it out?
Any help and advise welcome.
Thanks in advance.
Cab Rear Heater Blower
Rtaylor2208
Removing the rear set is pretty straight forward. Lift off the bottom section as it just clips into place.
Remove the bolts that hold on the rear seatbelts to the back rest. Lift the back rest of the rear seat upwards and off it comes.
Sounds like the blower may be goosed. Put an add up in the wanted section as you find another member will have a good used one in the depths of their garage.
Also best posting this type of question in the tech help section
Rtaylor2208
Ignore the let bit thought this was in general chat
Rtaylor2208
mrLEE30
the blower has two supplies, one for the fan and one for the heater element, although each supply is fed from the same relay, thus if you have smoke the power supply is getting past the relay.
It sounds like your fan has stopped but the heater element is still working, hence the smoke!.
remove seat base by pulling up from the front,
remove seat back by loctaing the two screws down near the seat belt lower fixings, remove the seat back bolts and slide the rear seat back upwards.
now you will see the blower. turn it on and hear if the fan is not working, if so i dont think they can be disassembled but worth a look as could just be soem dirt/hair in the fan motor that onyl requires a clean, otherwise a new blower unit is needed.
Gavla
That all seems pretty straight forward. Thanks for the help and advise, I will give it a try this week end if I have time.
