M20 tuning...
shortybmw
Post Wed Jan 18, 2012 11:37 am
Alrite guys, ive just bought a e30 325i touring and was just looking for some advice on get more power from
The engine without a engine swap. Whats everyone saying :)
tom325sport
Post Wed Jan 18, 2012 11:44 am
A good service always helps with these engines! Stick with the original BMW air box as the K+N ones don't do anything! A good chip is great - I have a 'Mild chip' and they are a great mod.
Also I've read that a good 6 branch manifold is worth it (BTB) but expensive.
I'm sure someone else with more knowledge will be able to point you in the right direction.
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Jan 18, 2012 11:57 am
Post Wed Jan 18, 2012 12:22 pm
BMWs where designed by engineers without too much interference from the accountants, so there's not a lot of compromise on the design. Consequently, there's not a lot to be gained by 'simple' mods, like there is with some other makes where a single performance limiting compromise can be identified and dealt with. Anyone who's worked on the old BL 'A' series 848cc engine will be aware of the astonishing percentage gains that could be made by a couple of hours grinding work on the head, unshrouding the inlet valves.
A good quality 'chip' can provide some minor, but worthwhile gains, but the biggest gains, short of bolting a big snail shaped thing to the side of it, or increasing its capacity, come from making it run as it did when it left the factory. When where the injectors last rebuilt, for instance, if ever?
tom325sport
Post Wed Jan 18, 2012 5:13 pm
Brianmoooore wrote:BMWs where designed by engineers without too much interference from the accountants, so there's not a lot of compromise on the design. Consequently, there's not a lot to be gained by 'simple' mods, like there is with some other makes where a single performance limiting compromise can be identified and dealt with. Anyone who's worked on the old BL 'A' series 848cc engine will be aware of the astonishing percentage gains that could be made by a couple of hours grinding work on the head, unshrouding the inlet valves.
I have to agree. I once had a natty m20 e30 that ran awful. After a full service it ran beautifully...!! I never had the injectors rebuilt however.
clipper
Post Wed Jan 18, 2012 5:36 pm
That's the one single thing that made the biggest noticeable improvement on my car amongst all the "Brianmooooreing*" I've done to it !
* Brianmooooreing = the act of returning a mechanically operated device to as close to factory specification as possible with funds permitted
kam-325i
Post Wed Jan 18, 2012 6:02 pm
See my Sig !
e301988325i
Post Wed Jan 18, 2012 6:05 pm
shortybmw wrote:Alrite guys, ive just bought a e30 325i touring and was just looking for some advice on get more power from
There are two schools of thought, you either want to retain the original M20 for whatever reason or you couldn't care less.
The former is for oddballs but there are plenty of us.
The latter is the cheapest way to performance, a car with 2k spent on an M20 wouldn't get near a car 2K on an M52 b28 engine conversion, or a 1K on a M30 b35 conversion.
As Brian said, there's no one item that will significantly fix an M20 and really your budget determines what you do.
1st step - A restorative service including injector clean is the first place to start, I got at least 10bhp from mine by fixing my TPS sensor.
2nd Step - chip from 'Speedtouch' on here. 5-7bhp
3rd Step - BBTB if you can find one. 3-4bhp
4th + 5th Step - BTB3 manifold - 1K fitted or £500 on a cam fitted if you're prepared to sacrifice bottom end torque. 10-15bhp each, 20-25bhp both.
6th step - ECU piggyback, MAF / alpha N conversion, possible injector upgrade. 5-10bhp depending on start point.
7th step - 2.7L or 2.8L Stroker conversion using the original pistons, easily 2K with 'I may as well whilst I'm there parts' 2.7L +15bhp / 2.8L +20bhp.
8th step - custom piston / stroker rebuild, budget 1K for pistons + block and head work on top of the the price for step 7.
I said:
e30topless said:
lock the wife in there
shortybmw
Post Wed Jan 18, 2012 11:14 pm
Ive got the stainless 6 branch ready to go on just undicided on wat to do about the rest of the system? Ive not got a mega budget id be happy with 200bhp out of it.. For the moment anyway, get paid on 15th so gunna get full service then. And i dont think the injectors have ever been rebuilt.
kam-325i
Post Wed Jan 18, 2012 11:16 pm
shortybmw wrote: id be happy with 200bhp out of it..
Your gonna be looking at serious money to get that kinda power out of a M20B25.
Its cheaper to swap engine for something like the M50B25
Post Thu Jan 19, 2012 7:34 am
Check the condition of the distributor cap & rotor arm.
If they are the 20+ year old originals you will be amazed what a difference a new set makes :D
Grrrmachine
Post Thu Jan 19, 2012 8:54 am
shortybmw wrote:ive not got a mega budget id be happy with 200bhp out of it
Even Alpina couldn't get more than 190 out of the lump, and that was with race cams fitted to a brand new engine with a matching exhaust system and remap. To cross the 200bhp mark you're going to have to jump to Step 7 in e301988325i's excellent list. This will cost $$$.
hongkongfuey
Mad-tango-geezer
Post Thu Jan 19, 2012 9:15 am
The best way to get a decent hp i have found, is m30 injectors and afm, get the chip from dmcl , bbtb , i can have one made if you send me a 2.5 throttle, cold air feed from the front grill, and 6 branch,
But do any mods after, service, check blue temp sender, check cap and rotor etc.
Ive got 192 from mine, ill put spec and pics when i can get on here on my pc
with cars like mine,
Post Thu Jan 19, 2012 10:19 am
HKF how much for a BBTB ?
Do you need to do any other mods if you fit one ?
Grrrmachine
Post Thu Jan 19, 2012 11:01 am
If you're interested in manifolds...
http://www.e30zone.net/e30zonewiki/inde ... #Manifolds
hongkongfuey
Mad-tango-geezer
Post Thu Jan 19, 2012 4:17 pm
its the internal bore that is increased, so nothing else needed, price machining + butterfly, ill price up and let you know
e301988325i
Post Thu Jan 19, 2012 6:51 pm
hongkongfuey wrote:its the internal bore that is increased, so nothing else needed, price machining + butterfly, ill price up and let you know
I've been pestered for these since I stopped doing them, you should advertise if you can get them done.
I said:
e301988325i
Post Thu Jan 19, 2012 6:58 pm
Thanks!
Although you could go the bolt on route of steps 1-6 to get to 200bhp, going straight in at step 7 will be similar money and you get a rebuilt engine out of it, the last thing a tired engine will tolerate is a cam being fitted and then being thrashed to the limiter regularly.
Ps) The M20 is limited to 7000rpm by the rockers, to go beyond this requires £500-700 of uprated rockers, it's an expensive route the engine responds much better to stroking.
I said:
Kos
Post Thu Jan 19, 2012 7:02 pm
hongkongfuey wrote:The best way to get a decent hp i have found, is m30 injectors and afm, get the chip from dmcl , bbtb , i can have one made if you send me a 2.5 throttle, cold air feed from the front grill, and 6 branch,
m30 injectors gain nothing. even 2.7's use stock injectors
skipunda
Post Thu Jan 19, 2012 7:32 pm
Image Someone prove or disprove the M30 injector route - graphs and paperwork. I suppose it's mainly linked to the bored out BBTB.
Chris
e301988325i
Post Thu Jan 19, 2012 7:43 pm
Well apart from having a superior design. If you were buying injectors form new for a custom build then 6 x 14lb M20 injectors would be chosen for a vehicle with a maximum power output of 168bhp, this is worked out roughly by:
This is not highly precise but is within 10%
hp per injector = lb flow x 2
14lb x 2 x 6 injectors= 168bhp, well done BMW.
so to cut a long story short the stock injectors are good for just that, stock!
Ideally an injector should not run over 85% duty to allow the coil time to cool and reduce the risk of failure during high loads, this is more of an issue for track work but none the less a good start point. Choosing a hugely oversized injector results in the inablility to despense small enough ammounts of fuel at idle.
If you're interested read here:
http://www.86transam.com/Bin/DFIFuelInjectors.pdf
It's also worth noting that the 027 M30 AFM mod only works in conjunction with M30 injectors.
I said:
skipunda
Post Thu Jan 19, 2012 7:47 pm
watching :thumb:
Chris
e301988325i
Post Thu Jan 19, 2012 8:39 pm
REworks dyno is rather pessimistic, mine made 20bhp less than at fritz optimistic rollers
edit - Rob, i'm not putting you down, if you remember I have M30 AFM and injectors. Do you remember the dyno day you organised at reworks that I came to? Mine made 20bhp less at REworks than at Fritz, later I went back to see how much my BTB manifold had given me (+10bhp) and Oakey-Dave turned up with his 2.7 tech 1 sport on TB's who made 30bhp less @ REworks than he had got elsewhere.
I'm suggesting your 192 is very modest.
What are you on about arguing with Gunni, he hasn't posted?
hongkongfuey wrote:
e301988325i wrote:REworks dyno is rather pessimistic, mine made 20bhp less than at fritz optimistic rollers
Dude running a cam too, and do u mean optimistic? Just cause people spend loads and dont make the mark, dont put down others.
You can argue wirh gunni about his stop, i think he knows more than most on here
I said:
HairyScreech
Post Thu Jan 19, 2012 8:50 pm
e301988325i wrote: Ps) The M20 is limited to 7000rpm by the rockers, to go beyond this requires £500-700 of uprated rockers,
not for much longer.
hongkongfuey
Mad-tango-geezer
Post Thu Jan 19, 2012 10:55 pm
e301988325i
Post Fri Jan 20, 2012 7:48 am
Edited my post above to better explain.
I said:
gooner1
Out humping Reindeer
Post Fri Jan 20, 2012 2:22 pm
Spill, Si, spill.
HairyScreech
Post Fri Jan 20, 2012 3:03 pm
Spill, Si, spill.
you have pm.
Post Fri Jan 20, 2012 7:39 pm
Ok, Alpina 2.7's use standard injectors. Explain that please.
e301988325i
Post Fri Jan 20, 2012 7:57 pm
bss325i wrote:Ok, Alpina 2.7's use standard injectors. Explain that please.
the bhp calc is 85% duty cycle. alpina are a tuning house and used up safety factor capacity instead of fitting a grands worth (at the time) of new replacement injectors? The same injectors can now be had for £40, mine are out of a V8 mustang and were imported from the states from ebay. . . The point is if you had to choose new injectors with a standalone ECU stock M20 injectors would not be chosen.
I said:
HairyScreech
Post Fri Jan 20, 2012 9:32 pm
are alpina pressure regulators different? as a pretty common trick at the time was to just tweak the pressure up a little, this simply scales the flow per second.
iv also done the math a couple of times for the stock injectors and found that there either really well matched to the 2.5 or are useless for extracting over 200hp, depending on how you want to look at it.
as for alpina sticking with stock injectors i cant explain it, the same way i cant explain why they put a hemisphere into the head and kept pistons with a b25 profile, or the decision to make custom pistons but not to increase the bore size.
some of the choices make financial sense and some engineering sense but seemingly at random.
Post Fri Jan 20, 2012 9:49 pm
HairyScreech wrote:are alpina pressure regulators different? as a pretty common trick at the time was to just tweak the pressure up a little, this simply scales the flow per second.
No.
They make 210bhp as well.
e301988325i
Post Fri Jan 20, 2012 9:58 pm
HairyScreech wrote:iv also done the math a couple of times for the stock injectors and found that there either really well matched to the 2.5 or are useless for extracting over 200hp, depending on how you want to look at it.
if they'd bored the block then they'd have that expense as well as bigger injectors! Alpinas were shockingly expensive, imagine an overbore and new injectors on top!
I said:
HairyScreech
Post Fri Jan 20, 2012 10:05 pm
exactly, financial sense but not engineering sense.
really if you were going to keep the same piston shape and bore size the logical decision would be to have 131mm rods made or to deck the block and fit a vernier depending on how pressing the financial need was.
