will an e36 steering rack go straight on
rajabilly
Post Wed Jan 18, 2012 1:27 am
hi wanted to put an e36 steering rack in was wondering how it would fit and wah parts would i need
redcar
Post Wed Jan 18, 2012 6:46 am
No it wouldn
And get an e46 rack instead
Its an easier swap and a better rack
Duke137
Post Wed Jan 18, 2012 8:08 am
redcar wrote:No it wouldn
It will fit with a small amount of effort, use the zone wiki to help you.
http://www.e30zone.net/e30zonewiki/inde ... onversions
I believe E46 and E36 racks are ultimately the same, it is only the "E46 clubsport" rack that has a "quicker" lock to lock.
You would need:
14mm spacers to mount it
E30 Tie rod assemblies (upper and lower)
Modified PAS Pipes
Modified coupling/UJ
If you want a "bolt on" set up, talk to DanThe on here, he can supply conversion parts that are top quality.
