Hi all, i need to replace all the rear bushes on my 89 325i Touring, tried ordering some bushes for my trailing arms and was asked if i want the bushes with eccentric holes or without!!
How can i find out what bushes i need without taking the trailing arm off, the car is my daily so its not a case of just removing and then ordering the parts.
Many thanks in advance.
Trailing arm bushes
Grrrmachine
- E30 Zone Wiki / Team Member
The eccentrics are available to correct existing issues with the suspension, such as bent beams or arms, or non-standard camber/toe setups.
If yours is just a standard touring, you just want the standard bushes; part number 33329061945
Don't forget to check the Wiki guide:
http://www.e30zone.net/e30zonewiki/inde ... Arm_Bushes
THEHOOD
Thanks Grrrmachine, I can get on and order them now!!!
It's actually quite likely that your car could benefit from the eccentric bushes, since bent rear suspension is far from uncommon on cars of this age.
Before you can fit them though, you would have to measure the toe and camber on your trailing arms with good standard bushes, then do some calculations to determine the angles to fit the eccentric bushes at to correct whatever is out of spec.
Most people just fit the concentric ones!
