Touring Headlining
fastdave
Post Tue Jan 17, 2012 5:36 pm
I am finally going to bite the bullet and have a go at fixing the roof lining on my touring , does anyone know where i might purchase some material for the job ? Cheers winkeye
KimH
Post Tue Jan 17, 2012 9:41 pm
I got a perfectly acceptable fabric and the some high temp spray on glue from AS-Trim off ebay.
Also look at wollies-trim.co.uk for more choice of original looking options.
My only regret is that I hurried refitting it around the sunroof aperture and the fabric wouldn't stretch properly back under the clamping strips at the corners. (Next time I will scrape the foam off the new fabric in these areas before attempting to clamp it up)
Good luck It's do-able if you take your time.
Cloggy Saint
Post Tue Jan 17, 2012 9:42 pm
Make sure your material is UV resistant.
Post Wed Jan 18, 2012 7:25 am
Good luck - I caved in and gave mine to a trimmer to sort out - results are brilliant but it wasnt cheap !
Remember if you want to do a proper job you also need to remove and re-cover the sunroof liner ( assuming you have one )
dips346
London Meets Main Man
Post Wed Jan 18, 2012 8:19 am
capri_rob wrote:Good luck - I caved in and gave mine to a trimmer to sort out - results are brilliant but it wasnt cheap !
what did it cost you ?
fastdave
Post Wed Jan 18, 2012 8:50 am
I did think about paying someone to fix it but they wanted over £400 notes :mad: Thanks for all the replys dave
Post Wed Jan 18, 2012 3:15 pm
Mine worked out about £300 - but it was the most expensive material they did and much of the labour cost was for prepping the base-board after removing the original material.
The glue residue from the old material is a pig to get off because it just clogs anything you try to sand it with and you shouldnt use any sort of solvent on it because you'll never get the new material to stick for long if you do.
