wiring in a none bmw engine
321gazza
Hi guys, fitted a none stanard bmw engine into my e30 318i 2door on a h plate, can i use the c101 pin 18 for the starter solinoid or should i wire it in so engine is independnt of the car, not using any of the dash as i have a stack system its a road car many thanks.
You can take the ignition live and start signal from the C101, plus connecting the fuel pump out from your replacement engine loom to it. You'll also have to do something with the unloader relay wire in the C101. Connecting it directly to the starter motor (the motor itself, not solenoid perm. live) terminal will work.
321gazza
thank you, do you have any numbers for the wires i need and how to do the unloader relay you mentioned.
Grrrmachine
- E30 Zone Wiki / Team Member
321gazza
Thank you guys, thats why the zone is the place to be if you own an e30.
