Cold start
chopper
Post Sun Jan 15, 2012 12:03 am
Hi all, my cabby has started playing games once again!! On cold starts it struggles to start and sometimes cuts out if you pull away, you have to wait until the idle drops before you drive off. I was thinking maybe it's either the fuel filter as I havnt changed it for a couple of years and the car hardly moves but have serviced it apart from the fuel filter. Or blue temp sensor but this is only about 6months old
Ajsingh
Post Sun Jan 15, 2012 3:03 am
Change the fuel filter!
E30 Crazy!
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Jan 15, 2012 7:58 am
What engine?
chopper
Post Sun Jan 15, 2012 10:57 am
Its an m20b25 sorry should of stated that. Yea gonna change the filter during the week
e301988325i
Post Sun Jan 15, 2012 11:07 am
If you barely use the car stale petrol. What you currently get at the pumps contains a bio element that evaporates to gunge and clogs everything.
I said:
e30topless said:
lock the wife in there
Grrrmachine
Post Sun Jan 15, 2012 11:31 am
Blue temp itself might be fine, but the wiring might be a bit crusty, especially the C191 plug under the inlet manifold.
If you changed the Blue Plug recently, have a quick look at its plug and make sure the terminals are located properly; some people pull the plug off via the wires and this damages the terminals inside.
Other than that, have you got any other symptoms in generally like a wonky or rough idle; something that would indicate an air leak? What condition are your spark plugs in?
chopper
Post Sun Jan 15, 2012 12:01 pm
Spark plugs are new, the idle revs up an down until the car is warm also when cold the car has intermittent power loss, but once warm everything is fine. That c191 Plug was chopped off and was replaced with bullet plugs and taped over.
e301988325i
Post Sun Jan 15, 2012 1:37 pm
chopper wrote:Spark plugs are new, the idle revs up an down until the car is warm also when cold the car has intermittent power loss, but once warm everything is fine. That c191 Plug was chopped off and was replaced with bullet plugs and taped over.
I'm afraid your bullet plugs, unless you have used very high spec sealed types which have been soldered to the wires are likely to cause problems.
Removal of the socket should be replaced by soldering the wires together and be covered with heatshrink insulation. The injector signals travel through here and poor connections will only result in poor running.
I said:
Grrrmachine
Post Sun Jan 15, 2012 1:48 pm
e301988325i wrote:The injector signals travel through here and poor connections will only result in poor running.
As does the blue temp sensor wiring. Best to unplug the ECU and do a resistance check across pins 24 and 45 to confirm that the readings are getting to the ECU ok.
chopper
Post Sun Jan 15, 2012 5:30 pm
I think the mechanic just used cheap halfords ones
