Suspension refresh - what bits do I need.
James90
Post Wed Jan 11, 2012 9:28 pm
Evening all.
I'm wanting to refresh the suspension on my car.
I have sorted the springs out.
I want to fit bilstein b4 dampers. I know the part numbers for these that I need so am all sorted there.
I will be getting those meyle e46 rear strut tops.
Which front strut tops shall I get?
What bump stops/dust covers do I need? (If anyone has part numbers that would be great)
I've read about a rear spreader plate for the rear strut tops - I know this won't really be necessary as I'm not running a big drop but I want to put it in anyway. Is this a bmw part?
'88 325i Auto Chromie Cabriolet in Alpine White
SGP
Post Wed Jan 11, 2012 10:44 pm
The M3 front top mounts are good, they will keep the geometry correct if you're slamming the front end. They're not cheap though.
If it ain't broke..
Fix it till it is :)
Sanchez
Post Wed Jan 11, 2012 10:47 pm
e46 rear cabby top mounts.
standard front top mounts will be fine for road use.
Use this site for your BMW part number.
http://bmwfans.info/parts/catalog/
James90
Post Wed Jan 11, 2012 11:22 pm
Not slamming the front end I will be going for a standard ride height, maybe switching to some eibach pro kit springs later on.
thanks for the link not seen that before usually use realoem
does anyone know who supplies bmw with the front top mounts? would rather avoid a trip to the stealer if possible
SGP
Post Wed Jan 11, 2012 11:34 pm
The standard ones from bmw are not expensive iirc.
If it ain't broke..
leeparkes
Post Wed Jan 11, 2012 11:39 pm
GSF an Europarts stock Lemforder bushes top mounts etc which is the same part that you'd get from BMW.
James90
Post Wed Jan 11, 2012 11:40 pm
Thanks thought it might have been lemforder I was aware that the subframe bushes are lemforder.
leeparkes
Post Wed Jan 11, 2012 11:44 pm
Avoid V-tech. 8O
Post Thu Jan 12, 2012 7:11 am
Lemforder front top mounts from ECP should be about £50 each.
The bump stops & Covers need to be ordered as a separate item from whoever you buy the Bilsteins from as they do not come with the dampers.
If you're doing a full refresh you also need :
Front & Rear Droplinks - Lemforder - ECP
Rear Subframe Bushes - Lemforder - ECP
Front & Rear ARB Bushes - BMW Dealer
E46 M3 Cab Rear Top Mounts - BMW Dealer
E30 M3 Front "Lollipop" bushes - BMW Dealer
Trailing Arm Bushes - BMW Dealer
Also worth considering if you want to get it properly "Tight" again :
Rear Diff bush ( Z3M ? ) - BMW Dealer
Engine Mounts
Gearbox mounts
Propshaft Donut.
Not cheap though :cry:
Post Thu Jan 12, 2012 9:02 am
The dust covers from your original Boge dampers will fit on your new rear B4s, and incorporate the all important load spreading washer underneath the rear top mount.
Note that BMW sell the M3 front control arm bushes as a pair. You only need to order one of the part number to get two bushes.
James90
Post Thu Jan 12, 2012 12:27 pm
leeparkes wrote:Avoid V-tech. 8O
I thought they were kids computers lol
capri_rob wrote:Lemforder front top mounts from ECP should be about £50 each.
How much?!?!
God knows what they are from the dealer then lol
Is this front and rear? the only thing I can frind from bilstein is this:
And that is from bilsteins catalogue - never found that at a retailer but I could ask them if they could get the part number i suppose.
capri_rob wrote: If you're doing a full refresh you also need :
droplinks - will they be supplied as a pair? they're about a tenner
subframe bushes - as above?
noted
got some already in a set a wishbones I got from someone on here - they're less than a year old so I'll make do with those for a bit
noted
capri_rob wrote: Also worth considering if you want to get it properly "Tight" again :
Engine Mounts
Gearbox mounts
Propshaft Donut.
Ooo I like it tight.
Rear diff bush - easy enough DIY job? any special tools?
Will get engine mounts from burton power
It's an auto box - where's best to get this from?
Propshaft donut - easy enough DIY job? any special tools?
Brianmoooore wrote:The dust covers from your original Boge dampers will fit on your new rear B4s, and incorporate the all important load spreading washer underneath the rear top mount.
Excellent thanks for clearing that up - So I don't need to buy anything extra for the rear suspension unit? Or will I still need to buy bump stops? (and are they what is pictured above^)
thanks for the info so far guys!
Sanchez
Post Thu Jan 12, 2012 6:09 pm
Thats dealer price, a pair from Cotswolds is 102.26 and a pair form ECP is 40.
James90
Post Thu Jan 12, 2012 7:20 pm
Right I've discovered that my pic up there from bilstein is for the front. Have emailed the supplier to see if they can get them for me.
The rear bump stop if I cant reuse my old one is bmw 33521125078
The front strut tops lemforder are £28 each from GSF just waiting for a price from ECP
Sanchez
Post Thu Jan 12, 2012 8:30 pm
James90 wrote:for a price from ECP
Front top Mounts are £18.95 each excl vat
Sanchez
Post Thu Jan 12, 2012 8:31 pm
^^must add thats from Matt(meatballs) on here who is ECP guy with e30zone discount.
Sanchez
Post Thu Jan 12, 2012 8:35 pm
James90 wrote:Right I've discovered that my pic up there from bilstein is for the front. Have emailed the supplier to see if they can get them for me.
Ide be interested in a set as well, can you let me know a price please.
Dont suppose you have spare bilstein collars for the struts by any chance?
James90
Post Thu Jan 12, 2012 9:10 pm
Will do mate, could possibly stick 2 sets on my order cos I think the minimum postage charge is quite dear.
I've not bought them yet but what do you mean by collars?
Post Thu Jan 12, 2012 9:22 pm
James90
Post Thu Jan 12, 2012 9:26 pm
What part number is that bilstein box of tricks then - is it the same as that one i posted^?
Do you have a part number for the prop donut handy? Is it easy to line it up properly afterwards? I don't want it to become unbalanced or anything?
Have you done the subframe bushes yet?
The trailing arm bushes - there are 2 sets available:
set rubber mounting eccentric 33329058822
set rubber mounting 33329061945
Are these like the wishbone bushes in that eccentric is better?
Post Thu Jan 12, 2012 9:35 pm
Don't know the part number for the Bilstein bits sorry - got mine from ECP before they stopped doing them.
No balanciing or anything required for the prop donut - seriously you don't need to buy it from the dealer as long as you get a Lemforder one from ECP or GSF
Subframe bushes I had done a couple of Years ago but they have hardly done any mileage since - if you don't have access to the special tool the only way is to drop the whole beam off the car and refurb it that way - take it to a local garage and give them some beer tokens to press the old bushes out and new ones in.
Standard rear trailing arm bushes are fine unless you have an adjustable beam setup.
James90
Post Thu Jan 12, 2012 9:40 pm
Ok no worries, Im guessing/hoping that the ones in the pic are just wrong. If not then I have no idea.
I meant the ECP/GSF part number if you had it - if not no worries. (I've been a victim of ECP giving me the wrong parts and by time I come to fit them...months later... they dont want to know lol)
No access to any special tools unfortunately - though I suppose taking the rear beam off will give me a good opportunity to do some de rusting of the rear end.
Well as I have no idea what an adjustable beam setup is I'll just get the normal ones!
Cheers for your help!
Post Thu Jan 12, 2012 9:46 pm
If you deal with Matt at ECP he is very good - I spent about £700 with him on one massive order last Year and it was absolutely perfect.
Its highly unlikely You would have an adjustable beam unless someone has got at the car in the past. Standard bushes will be fine.
Sanchez
Post Thu Jan 12, 2012 9:50 pm
James90 wrote:I've not bought them yet but what do you mean by collars?
The collar is the threaded metal ring that holds the shock in the strut. The bilstein strut doesnt have the same top indent as other struts so has different 'collars' which i dont have.
James90
Post Thu Jan 12, 2012 9:52 pm
I have sent him a PM so will see what happens.
I doubt it, the only non standard things I've found on this car are: the wheels (which are long gone now haha) and for some reason one of the front seat mounting points where there is meant to be a hole for a bolt to hold the seat in there is a very long thread sticking up.
Meatballs82
Post Fri Jan 13, 2012 8:59 am
[quote="James90"]I have sent him a PM so will see what happens.
Just replied mate :cool:
James90
Post Fri Jan 13, 2012 10:57 am
Thanks for that Matt!
Rob (or anyone) - What is the difference between the E30 diff bush and the Z3M one? Is it worth getting the one for the z3m?
Oh and Rob, In your bilstein box - did those concertina dust covers come with the same bump stops in my pic^?
Post Fri Jan 13, 2012 12:23 pm
James
I believe the Z3M bush is stiffer which reduces play in the transmission and also longer lasting - therefore a worthwhile upgrade.
Yes the bump-stops in your pic were the same as the ones I ordered - but I think I had to specify the concertina covers too - they all came in the same box.
James90
Post Fri Jan 13, 2012 12:27 pm
Ok will see if Matt can get me one of those if not I'll have a trip to the stealer once I get my daily back.
Ok cool will make sure I get them then.
James90
Post Fri Jan 13, 2012 2:33 pm
From the place I was going to get them from they are £25 + Delivery + Vat
But when adding them all to my basket and going to pay they added del and vat on everything which made them not the cheapest any more so the supplier I have found now is finding a price for them for me.
Will update you when they get back to me.
Ordered half the bushes from Matt, going to try GSF for the ones ECP don't do and if that fails then I'll be going to BMW 8O
