My touring boot lock doesnt work with the key and lock is vertical so alarm doesnt open it.
Can i remove the lock from the inside of the boot and swap if the boot closed and locked?
Cant get in the boot!!
Sanchez
adz79
If you have a new lock then a hammer and screwdriver is your friend to help you pop the lock. I had to do it on my 2dr when my Mrs's ex glued all the locks on my car but the only one it worked on was the boot.
bab-91
adz79 wrote: I had to do it on my 2dr when my Mrs's ex glued all the locks on my car but the only one it worked on was the boot.
Brilliant
Sanchez
No spare at the moment.
Any more ideas?
Going away nxt week n boot will be full.
Any more ideas?
Tay
lol your best bet is to climb into the boot and remove the trim and you'll be able to unlock it that way, if i were you i'd disconnect the solonoid from the lock itself when you've unlocked it. not ideal but it does mean you won't have to go at the boot with a screwdriver and hammer!!!! it probably just needs removal and a good clean!!!! your solonoid may have just seized????
Their is a 13mm adjustment nut on one arm of the U shaped piece in the hatch that engages with the catch. Unscrew this nut completely to release the hatch. It should be just accessible from inside the car with an open ended spanner.
The last two cases of non working boot locks I've come across (neither on an E30 touring) were caused by a 'spare' nut from someone's attempts to fit a boot lid spoiler, and a piece of glass from a shattered rear screen a year or so before, both of which had neatly lodged themselves in the mechanism.
Sanchez
theres are the answer im looking for, cheers folks.
Security is not a major issue cause the remote alarm can lock and unlock without the key but need the lock horizontal first.
