Hello,
Just wanted to ask...
How essential is it to have that loop from the e46 to cool the PAS fluid? I suppose that loop just fits in between the low pressure return and the reservoir
Also, do the pipes come out in the same place as an e36 rack?
The car would be driven on track.
Thank you.
e46 oil cooler
HairyScreech
apparently quite important with the e46 rack, theres a few accounts of fluid boiling with hard use.
redcar
Do you have any pictures of it installed on an e30?
Thank you.
Thank you.
TouringMatt
This is Alex's (e301988325i), along with this bit of advise he gave me
fitted mine in the same location but have retained the plastic rad air flow bit, as a result it comes through closer to the rad, but thats as far as i've got with the install, so im not sure if the pipes will foul anything, pump etcRemember the cooler runs in the return circuit;
My hose runs from a cut off hard pipe on the rack, around the front of the engine to the cooler, then from the cooler to the PAS bottle. The hose is cheap 2m should be under £10 so it's not exactly the end of the world if you get too much.
