Dead Auto box swap to manual??
jack-e30
Post Thu Jan 05, 2012 6:27 pm
I've got a 316i auto and for some reason the auto box has broken, i've been quoted £1500 for new parts and fitting ect and im not paying that. I wanted to know if i got a 18is engine and box and had them fitted what kind of price i'd be looking at??
I have found an Engine and box out of a e36 318is for £300
Thanks for any help
hongkongfuey
Mad-tango-geezer
Post Thu Jan 05, 2012 11:16 pm
I dont know if the e36 318 is engine goes straight in?, ur best bet is to get a manual box and pedals for yours, cheapest option , where are u based?
with cars like mine,
Jos
Post Fri Jan 06, 2012 12:59 pm
e36is engine will go in with the following:
sump from an M40/M42 e30 engine
custom dipstick (or bend existing one) if the engine has single serpentine belt on it
e30 M42 exhaust manifold - or some serious welding
loom from an e30 M42 or C101 spliced to the e36 loom, lots of cutting and tidying needed to get the e36 loom into the e30.
ECU (and EWS/key/pickup if fitted to the e36)
Gearboxes are different, 250 Getrag on the e36 usually, 240 on the e30, not an impossible fit but linkage and prop lengths will need adjusted.
Doable but if you just want the car back, look for a gearbox, cheaper and much less work. an e30 18is will go straight in, check the M40/M42 engine swap area for details.
'94 e36 tree climber
Post Fri Jan 06, 2012 1:13 pm
jack-e30 wrote:I've got a 316i auto and for some reason the auto box has broken, i've been quoted £1500 for new parts and fitting ect and im not paying that. I wanted to know if i got a 18is engine and box and had them fitted what kind of price i'd be looking at??
Thanks for any help
Unless you are doing all the work yourself, there is no such thing as a cheap engine conversion.
I can supply or supply and fit an excellent used auto box for your car and offer a guarantee for a
very reasonable price :)
PM me if you would like to discuss further.
