Got inside the cab today and thought the hood was leaking! Underneath the pedal on the carpet was slightly wet with a darkish stain. The clutch pedal is loose also.
I'm thinking clutch master cylinder? I took the cover off to have have a good look but can't see it leaking from anywhere.
I know that it is worth changing both the master and slave so I went to ECP and they told me they have both. The make of the cylinders are 'Pagid'? Are these any good and are they OE quality?
Clutch Master and Salve Cylinders
tom325sport
tom325sport
BTTT
tom325sport
Someone must know this?
pagid are a decent brand
ATE are the OEM make I believe
tom325sport
Thanks for this. Might get them ordered then.
