Idle sensor advice please
jesmond
Hi all
I've just read the idle blog in sticky items, very informative and extremely useful! However, I just need to check for a part number please guys for the blue sensor. My car is an '87 325i sport auto mtec 1. And also, is it a Coolant Temperature Sensor or is it a Thermotime sensor? The blog says the following:
"Motronic uses the Coolant Temperature Sensor to determine if the engine is cold or at operating temperature and adjusts the fuel supply accordingly. If it fails, it usually thinks the engine is cold, causing a rich mixture all the time.
The temp sensor is a blue sensor in the thermostat on top of the front of the engine. Don’t confuse it with the brown sensor which is only used for the gauge in the dashboard".
Thanks for your help
Paul
Paul
Grrrmachine
- E30 Zone Wiki / Team Member
In your car, there's a few sensors. There's a Crank Position Sensor that's used to detect the engine is spinning, a Temperature Sensor that measures the heat of the coolant (that's the blue plug), the Air Flow Meter that measures the flow of air into the engine (and its temperature). The closest thing to an "Idle Sensor" is the Throttle Position Switch which tells the engine whether the accelerator pedal has been pressed or not.
Only failure of the CPS will stop the engine from running, but the AFM, TS and TPS can all cause bad idle, as well as air leaks, worn ignition components and fuel supply issues. But don't just start buying new bits and swapping them in; you'll just add new issues on top of the existing one.
Have a read of the Wiki:
http://www.e30zone.net/e30zonewiki/inde ... ake#Idling
jesmond
Oh no, sorry, I DO mean the blue plug/sensor. It's just that there seems to be conflicting names for this - temp sensor - coolant temp sensor - thermotime sensor. I just need the name and the part number please.
Thanks again
Paul
Thanks again
Paul
Grrrmachine
13621709966 is the part number for the blue temp sensor. Have you tested it to make sure it's the cause of your issues?
http://www.e30zone.net/e30zonewiki/index.php/Blue_Plug
jesmond
Thanks very much for your help Grrrmachine, sound advice. I do agree that one can't just throw new parts at something without knowing the full story. However, my blue sensor does seem to to be playing up - good idle from cold, after warm up idle gets a bit uneven, and may even race on a bit. Seems to be over fuelling. All seems good as far as hoses etc, and the AFM and ICV seem to be fine. I've always kept my car in fairly good health. The only thing I can find so far is the blue sensor having no continuity at cold. I'll now check the resistance values after speaking to you guys, but I'm just getting some research done for the moment. Will act once I've made my final decision. I'll also check the TPS, and will have a good clean up everywhere. My money's on the blue TS though from what I can gather. I've replaced it once already, but that was about 8 or 9 years ago!
Thanks again everyone.
Paul
Paul
Grrrmachine
It might be the wiring from the sensor to the ECU rather than the sensor itself; that's why the Wiki states to test at the ECU plug, and THEN at the sensor. It'll only take 5 minutes with a multimeter.
jesmond
Yeah, will do. I think I've got the pins correct - 45 and 2. Not sure what you all mean by C191 though?
Grrrmachine
If you look underneath the intake manifold you'll see there's a round socket on the wiring loom. This is the C191 plug; it allows you to disconnect the injector wiring from the rest of the engine loom.
The wiring for the blue temp sensor also goes through this plug, and it's not uncommon for water to collect in there and rot out the wires, meaning the ECU gets faulty or no readings from the Blue Sensor.
That's why you need to test the Blue Temp sensor from the ECU plug.
jesmond
Right. So do I interrogate any of those wires in there too? Or just make sure no breaks and is generally clean etc? Which one is the blue temp wire in that plug? Or will that be obvious by colour or something?
Grrrmachine
As the Wiki for the Blue Plug states, get the ECU plug off and test the Blue Plug from there. Then unplug the connector from the Blue Plug and test it directly. If there's a difference, THEN you can inspect the C191 plug, but don't touch it at all without using a multimeter from the ECU plug first.
If you must fiddle with it without using a multimeter first (NOT recommended) then the coolant temp wire is brown/red, and goes into pin 1 of the C191.
jesmond
Okay bud, thanks for that, I won't do anything other than what you say. If I do end up needing to go further with the C191 I'll come back here first.
Thanks again
Paul
Thanks again
Paul
jesmond
Hi grrmachine. My TPS plug is round and has eight round pins, no doubt as it's switchable auto. Need to know how to interrogate that.
My ECU is 35 pin, how do you find the blue plug on that.
The only other connector in the engine bay which will disable the wiring looms is the large round connector plug on the firewall. I don't have a connector plug under the manifold. Please confirm that the firewall plug is indeed the C191. How do you interrogate that - i.e. where is no.1 pin etc.
Paul
Paul
Grrrmachine
Being a 1987 model, most of the wiring diagrams in the Wiki won't apply to you. I'll try to upload more pertinent ones, but it's a lot of work so it will take some time.
For now, your ECU plug connects to the coolant sensor at pin 13, with grounds at 5, 10, 17, 18 and 19. Your Throttle switch also goes to the ECU plug, with Open throttle at pin 3 and Closed throttle at pin 2. I can't find a wiring diagram of the 8-pin TPS just yet unfortunately.
If there's no connector under the manifold then you don't have a C191. The one of the firewall is C101, the main loom terminal to the engine bay, and its pinout is here:
http://www.e30zone.net/e30zonewiki/index.php/C101
You'll notice that no important engine data goes through the C101, since it goes straight to the ECU via the engine loom, not the main vehicle loom.
Can you confirm that your diagnostic plug is the earlier type?
http://www.e30zone.net/e30zonewiki/inde ... ostic_Plug
jesmond
Hi mate. Thanks for your help (again!). Don't worry too much about the TPS if it's a pain, you've given me loads of excellent help. I've had a good look at the TPS and it was fairly dirty, I've given it a good clean to the pins and the connector. Also gave the throttle body and outlets a good clean out. Should'nt do any harm, but haven't tried it yet. Will probably use it tomorrow. I have done all this before as general cleaning etc, but probably not for some years!
I confirm that the diagnostic plug on my car is the early type, very small, just at the front end of inlet manifold, near the engine oil dipstick. I've never counted the pins however, but I'm sure it will be the 15 pin job - I know the later type diagnostic plugs are just about the same size as the C101, which are definitely bigger than mine.
I'll play around a bit now that I can at least interrogate the blue plug from the ECU. If you do come up with anything else I'd appreciate your kind help again.
Cheers for now
Paul
Cheers for now
Paul
Grrrmachine
With the smaller plug, you'll have Motronic 1.0 or 1.1 rather than the later-style 1.3 engine management. That will help you search for info later on if you need more ECU pinout info. You may also want to consider upgrading to Motronic 1.3 in the future, as it will help you get more out of your engine.
There's not a huge amount of info out there on these earlier management systems, and I don't have any experience with them myself. Glad to be of some use though.
Tay
just a quick querie? when was the last time your clearances were done???? as sometimes it'll run fine when cold as it's throwing plenty of petrol in, but when the engine heats up it's a different ballgame??? i've had this a few times with poor idle when hot along with a collection of all the other things that have been stated!
jesmond
Yeah, fair comment bud. Funnily enough, they are due, I'm either going to do them myself (even bought a feeler guage the other week), or get them done. It's been on my mind, so we'll see.
Thanks for the message
Paul
Paul
Tay
no probs it's a nice easy job just do it when the engines cold and have the lobes fully down, with a clearance of 10thou or .25 metric put both as we had issues on another thread!!!!
