320 cabby odd lump of cast iron in my boot
knuckledragger
hi iv had this 320 cabby in my unit for a cuple of months now and iv just started work on it i empited the boot of all the parts but found a steel plate bolted down in the offside rear boot corner held down with 4 m8 bolt after removing this i was faced with a huge heavy lump of wat looks to be cast iron it is bmw as its cast in the bottom of it wat is it (is it somthing to do with battery in the boot ) is it realy needed????
Grrrmachine
- E30 Zone Wiki / Team Member
Do you think BMW would have put it there if it wasn't needed?
It's to do with weight distribution, to make sure there's enough load on the back wheels to give you proper grip, since you don't have a big heavy rear window, C-pillars and most of a roof weighing you down at the back.
Leave it be.
Leave it be.
mrLEE30
its a vibration damper to compensate for the lack of battery in the boot (and a 6 pot up front??) as in cabs battery is in the bonnet.
in reality removing it makes little difference as no doubt your worn bushes/different rims/lowered suspension (delete as appropriate) will have more effect on the car handling after twenty years.
you may safely remove it and see if you find a difference, i removed mine and found none.
It's a harmonic vibration damper, and if it wasn't needed it wouldn't be there.
A few years ago, Renault were top dog in F1, and it was eventually discovered that they had adopted this idea and fitted one into the nose cone of their cars. This was promptly banned by the powers that be, and Renault dropped back to being just another F1 team.
mrLEE30
I think the tuned damper of the R25 and the lump of metal in a cab boot are not exactly one and the same!!!
Renault used theirs to maintain a constant ride height and it was not fixed to the car and thus a movable aerodynamic device (hence its eventual ban) the lump in a cab boot i rememeber reading somewhere is to stop vibrations around the foot pedal area.
knuckledragger
well that ansered that for me it is just another bit of scrap it you say they wudnt have fitted it if it didnt need it i hsve 5 other e30 and alot of other frends with e30 and non of them have it fitted i will be fitting battery in the boot so it will deffo be being bind in favor of a numax
with all the extra wight in a cabby i would not have thought they wud need a lump of steel in the boot to slow it down some more
hazd31
Does this mean my cabby has it? Where abouts is it?
fuzzy
hazd31 wrote:Does this mean my cabby has it? Where abouts is it?
hazd31
Cheers fuzzy, im dislexic
I think i have a zone waiver on spelling somewhere.....
hazd31
Yep shes got it, The car handles worse the more weight i put in the boot, so a bit of testing without is needed!
Handling? Weight reduction? Make it faster? Are we still on about cabriolets?
If you can replace it with a similar weight battery then fair enough, but just ripping it out and binning it is a bit silly to say the least
knuckledragger
its having a numax dry cell battery and a m30 with a HX35 it will be a little faster i hope
Last edited by knuckledragger on Wed Jan 04, 2012 6:58 pm, edited 1 time in total.
It would need to be a fair sized battery TBH
knuckledragger
the car has got very little electrics on it im only running the windows an lights dash and ms2 ecu the marine numax batterys have massive cranking amps
I'll take it off you if it's in good condition>?
hazd31
Just pulled mine out, its gotta be 15kg at least!
Dont understand why its there? give you more traction? cant see how it would balance the car as its the same side as the driver.
Looks like new though, got some trick rubber bushes and all
Is it cast iron or lead?
It weighs just short of 23Kg, and it's a VIBRATION DAMPER. It's the weight that it is to give it a very specific resonant frequency - if it was heavier it wouldn't resonate at the correct frequency, and if it was lighter it wouldn't resonate at the correct frequency. If it didn't have those "trick rubber bushes" it wouldn't resonate at the correct frequency.
hazd31
So if i go for a drive ill get a funny noise?
Or will i just go a bit quicker, a bit more sideways and improve my mpg?
Morat
and even more rattly?
mrLEE30
mrLEE30 wrote: the lump in a cab boot i rememeber reading somewhere is to stop vibrations around the foot pedal area.
hazd31
Am yet to drive mine, need to get underneath and check the diff, its all clonky since i changed it, ill report back with the noise.
On the plus i now have a weight heavier than any weight in the gym
