Running issues - 320 Touring
andrew_baran
Post Tue Jan 03, 2012 12:47 am
Wondering if someone could shed some light for me:
I've got a fuel cut off switch (been there for ages) - splits the wire off at the rear seats, to a switch up front. The other day she died on a busy roundabout (typically) and the nice man from the AA found no way of getting her going again.
I bypassed the switch the next day (obviously the first candidate) and replaced the pump fuse and the battery, as it was on its last legs.
She started, and has been running ever since. Switch is still bypassed. But ever since the breakdown when I come off the throttle the revs drop to way below normal idle - to about 500rpm. The car shudders, nearing stall, before returning to the normal 800rpm. Sometimes does this a few times before settling.
Strangely, it seems to be better on BP ultimate. Although I wouldn't have thought fuel would be the problem, as the car has never complained about supermarket fuel before...
Is the fuel pump on the way out? It doesn't appear to be very noisy... Or is it something else I've overlooked? I'm far from an expert - would appreciate some opinions :)
Cheers.
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Jan 03, 2012 6:46 am
Could be a few other related issues; non-working Blue Temp sensor, gummed-up Throttle Position Switch, sticky Idle Control Valve or an air leak. I'd look into all of those before checking out the fuel pump.
Post Tue Jan 03, 2012 10:21 am
You say that your battery was on its last legs, so after it died I assume you gave it some starter motor action. Was this right up to the point where the battery did?
If so, you will have probably scrambled the ECU's idle settings, and it will need to relearn them.
It will do this simply by being driven, so I would ignore the poor idle problem for now, and see if it sorts itself out.
For the initial problem, it could really be anything, including the fuel pump. We don't really have anything to base a theory on.
Make sure the screwdriver is in your toolkit, and carry a 12 volt bulb attached to a couple of pieces of wire (indicator repeater is ideal.)
andrew_baran
Post Thu Jan 05, 2012 11:59 pm
So been through a few of your suggestions, here's an update:
- Scrambled ECU settings.
Done a few hundred miles now, over a few starts. Sometimes it's OK, sometimes its not. Most recently, it hasn't been any different - still hunting on idle.
- ICV
Unplugging the ICV makes it idle much better! Seems to completely solve the problem. The car has terrible throttle response when it's plugged in, but totally perfect once its unplugged. Idle always returns right, and it all feels fine.
What happens when the ICV is removed? Does it default to a value? Or is removing it compensating for another issue?
