TPS Ohm readings
pcs
Hi....checking my 6 pin TPS with a meter but not sure what values I should be getting. Is there some where the correct values can be found, or if someone knows them could they post them please. Will the potentiometer aspect of the TPS radically influence the TCU and the gear changes? Thanks for any advice and help.
Rtaylor2208
Have a look through one of my old threads. I assume you have an auto too as its a 6 pin TPS.
pcs
Hi...Rtaylor. Thanks for the reply. Yes mine is the EH switchable auto. Do you know how much the pins 1 to 3 part of this TPS effects the gear change? And if when adjusting the alignment of the TPS, this will alter the signal to the TCU? My change from 1st to 2nd gear is a bit harsh, as the car seems to hold in 1st perhaps a bit too long. Had the transmission serviced after buying the car and the fellow doing the work said the TPS had no room for adjustment left.....if there was more he could smooth the gear change. At that stage I didn't understand what he was talking about, and he unfortunately didn't elaborate...so it's only recently have found out about the dual role this TPS plays..Haines or Bentley don't give any info about this, so am keen to read about it or be told by someone who knows.....I'm pretty sure the pins 4 to 6 idle/WOT is working okay.
Rtaylor2208
I only concentrated on the 3 pins that relate to getting the idle right and not the auto box part. So I'm afraid I have no idea, but as you say it's not covered in the Bentley manual or Haynes. A BMW dealer or specialist may be the only solution unless someone else on here knows best.
pcs
Thanks again.......I'll keep asking around and will try BMW as well.....I'll go and have a chat with the guy who did the original tranny service and see if he will shed more light on this. Thanks
