Blue temp sensor testing procedure
nickphine
Post Sun Jan 01, 2012 12:57 pm
Hi there, i have been testing my blue temp sensor as per instructions on the zone with the following results:
Cold resistance readings
At sensor 4500 ohms
At c191 (think that is what its called) 4500 ohms
Other side of c191 plug 6500 ohms
At ecu plug - can't get a reading
Hot resistance reading at sensor 300 ohms
Now i am admittedly a complete remtard at electrics, but from what i can fathom that sounds wrong. Symptoms of running are, runs fine cold, bit lumpy but always has been, now struggling to start when warm and black smoke sometimes when warm, juddering on full power, but it is sporadic, i.e. Works fine sometimes and not others.
Any help much appreciated, cheers nick hine
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Jan 01, 2012 1:05 pm
Knowing what car you have helps.
But if you can't get a reading at the ECU plug, then the car is going to be massively overfuelling from cold to the point where it stumbles and cuts out when warm.
The sensor itself looks ok, so it could be corrosion around the C191 plug, which is likely.
Check again at the ECU plug until you get a reading. If you can't, be prepared to either call in an auto electrician, or fork out for a new engine loom. You really need to see the same readings at the ECU pin as you're seeing at the sensor itself, both hot and cold.
For more info, see here:
http://www.e30zone.net/e30zonewiki/index.php/Blue_Plug
nickphine
Post Sun Jan 01, 2012 4:33 pm
Yep, sorry, 325, well m20b28. I ave a spare loom so can check it and swap it over, maybe easiest. Swapping to cars isthe plan so need to spend as little as possible!
Post Sun Jan 01, 2012 11:02 pm
All initial testing of a blue temp sensor should be done at the ECU plug only. To get meaningful test results it's important that you don't disturb what you are trying to test, as this is likely to mess up the results.
From what you've said, it looks like you have a problem at or near the C191, either with corrosion on the pins, or, more likely corroded wires under the rubber cover on the lower part, as a result of the official mod. not having been done, and water trapped in there.
nickphine
Post Mon Jan 02, 2012 7:12 pm
Thanks for that, I'll trace it back and check it against my other loom. It should be pins 24 and 45, have I got my facts right?
mrLEE30
Post Tue Jan 03, 2012 6:53 am
remove the ECU plug and identify pin 45 and pin 2 on the cable side (pin 45 should be brown/red wire going to it, pin 2 has brown)
then set you meter to measure resistance.
with the engine completely cold measure from the pin 45 to ground, and then from pin 45 to pin 2, the resistance should be about 2-3000 ohms for each case. now refit and run the car till hot, remove and re measure and you should have 2-300 ohms for each case. If this does not happen then report you findings.
nickphine
Post Tue Jan 03, 2012 12:04 pm
Aha, those pins make more sense, I'll have a go later, cheers.
nickphine
Post Sun Jan 15, 2012 5:36 pm
Just had chance to test this today. Ran it for 30 mins perfectly. Figures were 5.77K ohms cold both at the ECU plug and Temp sensor itself. Then 0.38K ohms hot both at the ECU plug and Temp sensor.
Problem appears to have dissapeared, maybe down to the fact that I've had the C191 plug apart and checked all the connections, there were no obvious signs of corrosion anywhere in or around the plug though.
The readings seem a little high but the thing is obviously working to a certain extent.
Cheers for everyones help, fingers crossed it's gone away, kind regards
Nick Hine
Post Sun Jan 15, 2012 8:52 pm
Lee's idea of a 'cold' engine is one that's at about 35 degrees! For us in this part of the world, and at this time of year, I'd expect well over 4000 ohms cold, and probably a bit more where you are.
The 'hot' reading is high, but this could just be the delay between stopping the engine and getting the meter hooked up. The reading soon starts to climb after an engine is stopped.
nickphine
Post Mon Jan 16, 2012 9:16 am
Yep, cold here yesterday was cold. It took me about 2 mins to test after I'd switched the engine off. Last time i tested it I couldn't get a reading at the ECU, then fiddled with the plug and the problem seems to have dissapeared. hmmm.
Grrrmachine
Post Mon Jan 16, 2012 9:56 am
If you're rough with the actual plug that fits the Blue Temp Sensor, then you can pull the terminals out of position so that they don't make a connection. I did this with mine by pulling the wire instead of the plug.
That's why it's important to test at the ECU.
mrLEE30
Post Tue Jan 17, 2012 1:43 pm
Brian it has dropped to 21 here today, brrrrrrrr!
Post Tue Jan 17, 2012 7:01 pm
Grrrmachine wrote:If you're rough with the actual plug that fits the Blue Temp Sensor, then you can pull the terminals out of position so that they don't make a connection. I did this with mine by pulling the wire instead of the plug.
You can also mess up plugs by pushing the probes of a meter into the buckets and stretching them!
When you test at the ECU plug, be careful not to damage it. push the stripped off end of a piece of wire (no bigger than the pins in the ECU) into the plug, not the meter probes.
Dropped into the 20's here last night, as well Lee, but I think you may be talking Celsius, while I'm on Fahrenheit!
