wiring diagram for electric hood
320icab
Post Sat Dec 31, 2011 3:05 pm
Hi guys.
Been trying to source literature on the wiring of the electric soft tops. do any of you have the schematic for this or anything that may be of use?
So far,
.I've checked for power at the relays in boot - 12v
.I've checked and made sure all connectors in boot are plugged in and motors engaged
.Checked for power at switch on dash - no power but switch operational as get a resistance when switching
.Tried to trace wiring to find fuse - no such luck
.all mechanical components that lay inside the horseshoe are in working order and moving freely as hood still operates manually with no problem
I have all literature on set-up and syncing of micro switches but there is nothing that shows the actual wiring.
Anything you can pass on will be greatly appreciated.
Thanks,
Lance
Gert_8
Post Sat Dec 31, 2011 4:15 pm
Hello.
Please let em know how you get on, as I have a similar problem. I disengaged the motor to fit a new opening arm, but when I reconnected it, it failed to work. I will most probably have a look at this in the spring,however, the following might help you - and there is a wiring diagram you wanted.
http://www.e30zone.net/e30zonewiki/imag ... etting.pdf
Cheers.
320icab
Post Sat Dec 31, 2011 4:21 pm
Thank you very much, I'll check this out. Probe wont get onto it until next weekend but will update when the time comes.
320icab
Post Sun Jan 01, 2012 9:40 am
Hi Gert_8,
Had a look at the literature you supplied link to - thanks :-D.
However, the wiring diagram relates only to the circuit of the hood and doesn't include the wiring in car which supplies the hood with power. Do you know the fuse location/ number? This is the part im struggling with as without removing dash, I'm having difficulty tracing the wires from the back of switch to point of origin(fuse box).
Cheers,
Lance
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Jan 01, 2012 10:12 am
Gimme 10 mins and I'll upload the wiring to the Wiring Diagrams in the Wiki:
http://www.e30zone.net/e30zonewiki/inde ... g_Diagrams
They will be marked Convertible Top
EDIT: Done
Gert_8
Post Sun Jan 01, 2012 11:51 am
Thanks Grrr I wouldn't have been able to help without that! :D
320icab
Post Sun Jan 01, 2012 12:30 pm
Perfect,
Thanks for the help guys.
