What do you do with it? i need to bypass it so the car cranks over.
Any ideas?
auto to manual inhibitor switch?
bypass it si,
drop the glovebox and behind the upper plastic trim you should find a Black/yellow wire plugged into to another black yellow wire, on the big clump of wires that comes from the back of the fusebox,
you will also find a spare tail that is also black/yellow, disconnect the 2 and plug the spare tail back in
i've sorted it cheers. Bloody car just won't start no spark
