Not long had the car but the front bumper below the number plate has a section cut out and a oil cooler is there , is this standard on e30 325i manual on a j plate, I ask as i was looking at rads on the net and some of the rads are advertised from auto and say "will fit the manual but does have the holes (feeds) for the oil cooler on the autos.
would post a pic but unsure how to? many thanks peeps
MY 325I HAS A OIL COOLER IS THIS STANDARD
redcar
yes
325's have separate oil cooler as standard.
Autos have a cooler also built into the rad which is to cool the auto gearbox fluid I believe
Correct, and this has nothing whatsoever to do with the 325's engine oil cooler.E30BeemerLad wrote: Autos have a cooler also built into the rad which is to cool the auto gearbox fluid I believe
The water radiator intended for an auto car can be used on a manual car with no mods whatsoever.
TouringTash
hi Rich for an old car an E30 does have some good engineering built in.
For sorting out pictures have a read of this http://www.e30zone.net/modules.php?name ... c&t=171646
It may sound daunting at first but follow the instructions and you won't go wrong.
I still preview the post to make sure I've got the pictures right as the Mrs would do her nut if I used the wrong link.
318i Touring
richeg33
So buying a normal 325 rad is fine then ? Thanks for the help guys and cheers for the info touring Tash
TouringTash
HTH (happy to help)
318i Touring
