modified m20/m50 sump
makman
customised m50/m20 sump! is this possible to cut the m20 sump flange off and weld it to an m50 flange to make a front panned m50 version to do the conversion with seen as though the e34 ones so hard to find??
Canny Beat a chromie!'
I suppose it might be just about possible, but after youve spent days/weeks faffing about chopping stuff up and paying somebody to weld it properly, then redesigning the oil pickup/pump mounting etc etc you will wish you'd spent the £100 odd for an E34 sump and had it done in an hour.
makman
well tbh i will spent 100 quid on one but i simply cant find one too buy lol..im a engineer eniways so il do the fabrication and welding. it could work though couldnt it? (please say yes)
aha
aha
Well if I was going to do it id be more inclined to make a custom shallow sump rather than graft the M20 bottom to it
Jimbob
Look for E38 728i breakers as well.
