Cooling hose connect where ?
Jonascbc
Post Tue Dec 27, 2011 9:24 pm
Hello
I have just got my new engine, from faceliftet model, and one of the hoses, I can´t figure out where to connect.
http://bmwfans.info/parts/catalog/E30/4 ... ter_hoses/
Number 13. At clamp 15 ?
Is it the outlet to the heating ?
If it is I have to bent it pretty much?
Sorry if my english sucks, not rarely write it ;D
Post Tue Dec 27, 2011 9:33 pm
Not quite sure I understand what you're asking, but the end of the 'tee' hose, 13, goes to the top heater pipe on the bulkhead (where it shows hose clamp 15).
Pipe 12 goes from the back of the cylinder head to the bottom heater pipe on the bulkhead.
It is important that the two heater connections are the right way around, which is as above. They lie more naturally the other way around, which is wrong.
Jonascbc
Post Tue Dec 27, 2011 9:37 pm
It was just what I meant
Was fairly aware of the other ends
And thanks for the advice! Will try to remember it
