performance clutch on m20 stroker
Gabriel
Post Mon Dec 26, 2011 2:02 pm
hi,
Is it necessary to put in a performance clutch for a m20 with the following specs:
Stroker kit Ireland engineering 2.9
272 cam
bigger valves
Megasquirt spark and fuel
was thinking about a stage 1 F1 clutch or something like that (till 240hp and 300Nm) but is it necessary?
cause i am planning to convert my e30 to turbo in the near future (2 years or so) so will be in need of a 6 puck clutch then, but i am not willing to put one in right now because of the worse city driveability with the 6 puck
Or should i just go for a new stock clutch disc and leave it with that?
Post Mon Dec 26, 2011 2:06 pm
Standard clutch with a 325 cover plate will be more than man enough to handle that spec.
