Touring Struts
TPS
Post Sat Dec 24, 2011 7:42 pm
I'm trying to find out what size Struts are on my 1994 318i Touring? 45mm or 51mm? What size are the rears? Are they the same as my 325 ones?
Phil
Post Sat Dec 24, 2011 8:04 pm
A lot can have happened since 1994, but it had 51mm struts when it left the factory, identical to any other E30 51mm struts.
Rears? There aren't any struts on the rear.
The only difference between your trailing arms and 325 ones is the brake callipers, which have a slightly different piston size.
TPS
Post Sat Dec 24, 2011 8:08 pm
Thanks Brian, I meant to say are the rear shocks, the same as whats on my 325 Touring?
Post Sat Dec 24, 2011 8:18 pm
Rear shocks are the same or at least interchangeable. If they're the originals, they are unlikely to have much damping left.
