refitting window seals
SGP
I'm about to refit the windows, doors and boot lid seal on a restoration, (2dr). Should I use a sealant of some kind. or just clean up the rubbers and hope for the best? I'm concerned that the head lining may 'wick' moisture through the seals. Thanks for your help.
If it ain't broke..
Fix it till it is
Fix it till it is
Fabric parts, such as the headlining, etc., are glued where they lip over the door or windoow apertures, but nothing is required on any of the rubber parts.
SGP
Thanks Brian.
If it ain't broke..
Fix it till it is
Fix it till it is
