bad earth?
adi1987
I've noticed on idle my headlights are a bit dim, that is until I rev the engine. Also my blower fan on speed 4, will speed up if I rev the engine. Could this be a bad earth?
Only if it's on the alternator!
Measure the voltage on the battery with everything off, and again with the engine running at idle, and at around 2500 RPM, then again with the headlamps full on, the rear window on and the heater fan full on.
It's quite normal for the lights to brighten slightly and the fan to speed up a little when you come off idle, if there's a heavy electrical load.
adi1987
thanks for that, I'l check over it sometime over the christmas break.
