RPM and MPG gauge not working.
jonofdoom
Post Fri Dec 23, 2011 3:05 pm
Hello..
As the title says, my RPM and MPG gauges have just stopped working today.. Wondering if anyone knows any obvious things I should try?
Car is a '90 318is. UK spec RHD and all that jazz.
Just before they stopped working I had jump started it, and messed about with a few fuses trying to sort an unrelated radio issue. I'm 99% sure I put all fuses where they should be and all looked good, but had to mention it just in case there's a specific RPM/MPG fuse or anything. Can't see one in the owners manual, nor can I fathom any reason why jump starting might be any kind of cause, but worth mentioning I suppose.
All the other gauges work just fine.
Anyways. It's very annoying so any help much appreciated:)
Oh, and to make matters potentially even more annoying, I also just noticed a mouse has taken a shine to the oil rag that lives under the bonnet. No more oil rag then, and hours of hell searching for chewed wires will follow if there's no obvious things to try first.
Thanks.
TouringTash
Post Fri Dec 23, 2011 3:17 pm
A browse through the tech thread titles would be my first port of call.
318i Touring
Post Fri Dec 23, 2011 4:54 pm
Do the service indicator LEDs work properly?
jonofdoom
Post Fri Dec 23, 2011 6:46 pm
Thanks for replying:)
Best I can find on google / forums this thread:http://forums.bimmerforums.com/forum/sh ... ?t=1651402
Mentioned in which are cluster batteries, earth issues, and in his case the coding plug, whatever that is. They're all on the list when I get a chance to dig about a bit, though the coding plug is a bit mysterious to me - I'm used to much less high-tech transport.
Yes all the service indicators are working as normal..
To add to the confusion, now that it's dark I noticed the cabin lights also no longer work.
Post Fri Dec 23, 2011 6:59 pm
Replace fuse 21.
This fuse is for the cabin lights, and amongst other things, supplies the charging current for the SI indicator's memory batteries. If the SI board has the NiCd version of the batteries, they are on their last legs, and are deprived of their charging current, they may well prevent the tacho and econometer from working.
The batteries may or may not recover with the supply restored.
Common causes of fuse 21 blowing are radio installations to the usual aftermarket standard or a damaged wire on the boot lid hinge.
jonofdoom
Post Fri Dec 23, 2011 7:07 pm
That would make an awful lot of sense, thanks very much, I'l go try it right now.
Radio wiring behind the dash is indeed "to the usual aftermarket standard".
jonofdoom
Post Fri Dec 23, 2011 7:25 pm
Bingo, fuse 21.
Thanks very much.. I can't quite express how much better I feel knowing that I'm not going to have to chase electrical faults, it's really not my thing at ALL.
Very appreciated indeed.
Jon.
