drivers door not locking?
RichIS
Post Thu Dec 22, 2011 11:42 am
on this 318i coupe ive got batterys gone flat and now the batterys ok and the car starts even if left days with out toucing it
problem is now the drivers door cant be locked relay makes a noise when you try locking it but the door pin doesnt want to move no matter wat any ideas on how to get it to lock?
as long as it locks dosnt matter if central locking is inop
cheers
Injections nice....but I'd rather be blown ;)
Rtaylor2208
Post Thu Dec 22, 2011 1:17 pm
Best to take the door card off and you will see the lock mechanism inside the door. That way you can see what happens when the key is turned if the lock arm connects with the mechanism inside to lock it.
Mine is the same locks but does not unlock. Turned out to be the lock itself was broken. Have bought a full set of locks from another zoner to replace them all.
You can get a lock rebuild kit from BWM for £20, there is a good description in the wiki if you need it.
Never tried this myself as my boot lock is also a different key so just bought a full set instead.
Post Thu Dec 22, 2011 11:11 pm
The reason the driver's door doesn't lock/unlock on the key, without the assistance of the central locking is basically lack of lubrication and maintenance. A refurb of the mechanism and linkage, possibly with the replacement of the alloy L shaped piece on the back of the lock barrel will sort it out.
An easier solution will probably be to get the central locking working again. From your description, the well documented "red/black wire mod." will do the job.
RichIS
Post Sat Dec 24, 2011 5:41 pm
black/red wire mod done and we have working locks :)
