drivers foot well carpet
jimbob29
need to check around accelerator area for leaks/rust ect how do i lift the carpet?
Duke137
You need to take the underdash panel out, front kick speaker panel off, sill trims, drivers seat possibly centre consoles if you need to see that far over, remove drivers seat and unclip the accelerator so the carpet can slide over it.
You may also need to cut the carpet around the steering column if it restricts the movement.
Depends what you need to see? If it is the usual corner behind the accelerator, you should be able to get a look in. It is bloody frustrating though, juggling the carpet
jimbob29
how do i remove the plastic trim??
Slide them forwards (may require the use of a small hammer and a wide bladed chisel), until the trim is clear of the rearmost clip.
Slide the trim backwards, bending it slightly out at the back, so that it rides over the clip, and it will come right off, undamaged, but leaving the clips in the sill,
You now need a trim removal tool to remove all the clips.
To refit the trim, slide all the clips back into the trim, space them out to their correct places, and push the trim complete with clips back into the holes.
asmith88
or just rip it up and break half the clips like me,
1990 brilliant red 318 is
SGP
Have a good look underneath the car around the square plate welded to the underside of the floor beneath the throttle pedal. Rust is guaranteed here. Save yourself the bother and don't lift it till you're in a position to fix it. and get it welded up proper like.
If it ain't broke..
Fix it till it is
Fix it till it is
SGP
The part no. for the sill trim clips anyone ? I will be needing a few
If it ain't broke..
Fix it till it is
Fix it till it is
