e46 rack spline too long?
DC2011
Post Tue Dec 20, 2011 12:42 pm
Hi,
I have just offered the rack up and the spline that connects to the steering column seems to be longer than the original, there is also a plastic sleeve with a straight edge that looks as if it would go through the slit in the coupling however the whole lot looks as if it will be about an inch too long.
Do the 14mm spacers need to go underneath the rack to push the thing up or do I need to put them ontop to bring the thing down slightly?
Cheers, Dan
e301988325i
Post Tue Dec 20, 2011 1:19 pm
IIRC correctly that plastic sleeve needs a trim, also my rack is mounted centrally with the coupling shortened.
I said:
e30topless said:
lock the wife in there
Post Tue Dec 20, 2011 3:02 pm
Spacers must be positioned to keep the new rack in the same vertical position as the old one, otherwise you will introduce bump steer.
DC2011
Post Tue Dec 20, 2011 3:35 pm
cheers,
I have read a few of your posts on this topic before.
So the sleeve needs chopping up thats no probs but as for the coupling being shortened is this essential to get it to fit on a standard 318i or is it due to a clash with a more 'meaty' manifold?
I don't think putting the 14mm spacers above the rack will work anyway as the rack looks as if it will clash with the front subframe.
And reading into another post it seems that the mod needed is to use 2 e34 steering couplings: butcher one to get the lower section of the upper coupling to marry with the original upper section (e30) and the lower (e34) coupling is left 'as is' and installed directly onto the e46 rack.
Sorry for the poor explanation but your help is much appreciated.
Duke137
Post Tue Dec 20, 2011 3:51 pm
http://www.e30zone.net/e30zonewiki/inde ... onversions
Read this ^^^^
You need to combine the E36/E30 coupling as the spline on the end of the E30 steering column is different to E36/E46 racks IIRC.
The 2 x E34 UJ thing is for those who have an M52 and need the space to clear the manifold. DanThe is the zoner who does this, he basically splits one of the E34 UJ's and joins it to the top part of the E30 coupling (the knuckle) to allow this all to happen. You should be able to use the wiki link I have posted to do yours for a 318i.
Hope that helps
PS Plastic part definately needs cutting off the rack. When you get to the pipes you need to re bend them. B15NAC on here did it with a Ring spanner, vice and blow torch. Try doing a search on that one.
Duke137
Post Tue Dec 20, 2011 3:55 pm
http://www.e30zone.net/modules.php?name ... c&t=188638
Bit more info here when Dan first started doing them for the engine conversions and also M20 engines.
DC2011
Post Tue Dec 20, 2011 6:03 pm
thanks duke 137, :D
I have just got the universal joints section off mine. (what's this called?)
So a e36 lower UJ will fit the spline from the e46 rack?
Also so i am up on the lingo whats the IIRC? :?
Cheers dan
Post Tue Dec 20, 2011 6:40 pm
You dont need to chop the plastic dust cover if you shorten the linkage enough, dont remove it either like some have been doing, its there to keep crud out of the rack
redcar
Post Tue Dec 20, 2011 7:07 pm
i couldn't get my linkage to clear the downpipes on my m40.
On the m42 it clears the manifold, but only by a few mm.
You have to play with where you want the rack, front holes or rear? And if you want spacers below or above the rack. Moving it around allows you to possibly have a position which clears the manifold.
The problem with the linkage hitting the manifold is actually the Universal Join (lower one) touches the manifold.
I'm not sure the 2x e34 UJs with the thin steering shaft would solve this problem. I believe a way around it is to machine the lower universal joint.
Please let me know if you find a solution that works allowing your steering linkage to clear the m40 downpipes as i'm also having trouble on my m42.
redcar
Post Tue Dec 20, 2011 7:10 pm
By the way the steering linkage i have is this exact one used following the guide
Just the lower UJ which touches the manifold when in a certain position.
sweep
Post Tue Dec 20, 2011 7:18 pm
I had my original linkage cut down and re welded/sleeved on my 325i with btb3
If the UJ is touching the exhaust then you need to mod the exhaust too, only way round the problem
redcar
Post Tue Dec 20, 2011 7:26 pm
DanThe wrote:If the UJ is touching the exhaust then you need to mod the exhaust too, only way round the problem
Oh ok, i think my engine mounts could be gone.
I'm using the steering linkage my brother had when he had the e36 rack in his s38 e30 and that cleared the manifold, so i'm going to use poly engine mounts and see if they lift the engine up a little bit or something.
I don't know, i thought it was quite common to have an e36 rack on a 318is so i'm unsure as to why my manifold seems to be only about 3mm from the steering linkage.
Think the poly engine mounts might solve it though.
Duke137
Post Tue Dec 20, 2011 7:31 pm
This. You can't hack the UJ about, if it fouls the manifold then it is the manifold that needs adapting. The E34 UJ's and shaft.
The E34 UJ's and shaft mod is good because it is probably the thinnest coupling you can use, if it touches the manifold still then the mani will have to modded.
You could do what Sweep did have it welded/sleeved but it will have to be an A1 job as I think welded steering components/suspension can fail MOT's????
IIRC = If I remember correctly
AFAIK = As far as I know
Duke137
Post Tue Dec 20, 2011 7:33 pm
DanThe wrote:You dont need to chop the plastic dust cover if you shorten the linkage enough, dont remove it either like some have been doing, its there to keep crud out of the rack
You can easily trim the little piece that fouls without removing the dustguard and make a nice neat job of it 8)
My E36 rack didn't have this but my E46 rack did
sweep
Post Tue Dec 20, 2011 7:38 pm
Mine has been profesionally done and the weld cant even be seen
Post Tue Dec 20, 2011 7:39 pm
It's not a difficult job to move the steering column outwards a little where it comes though the bulkhead.
Duke137
Post Wed Dec 21, 2011 1:19 pm
Brianmoooore wrote:It's not a difficult job to move the steering column outwards a little where it comes though the bulkhead.
What do you mean, extend or literally move it across?
