E30 318 ENGINE PROBLEM
22sas
Post Mon Dec 19, 2011 6:32 pm
Hi guys got problems with my e30 it's like it's running out of fuel (jerking lol). So I changed the fuel filter today and still no better phoned the aa and he said it's probably a ignition problem. The cars at the garage now so just wondering if any one else has had the same problem and what the cause was cheers . sorry it's a 318 g plate
redcar
Post Mon Dec 19, 2011 7:18 pm
I had this same problem
You need a rotor arm, distributor cap and new ignition lead set.
Get brand new ones and it will should be normal again.
chh137
Post Mon Dec 19, 2011 7:23 pm
Plus new spark plugs for what they cost.
TouringTash
Post Mon Dec 19, 2011 7:25 pm
Forget the lead set, A few older zoners will attest that they have never seen a set fail.
Whats with your name 22sas ? fucking loose that sunshine you're taking the fucking piss!
Do you have family that have/are serving? I do not expect a reply but think about that title and what it means.
318i Touring
22sas
Post Mon Dec 19, 2011 7:33 pm
yes thought so got them on order going to fit it all 2moz and the user name is just something thats stuck m8 lol might take your advise though.
TouringTash
Post Mon Dec 19, 2011 7:37 pm
OK so you live in the same town as the RHQ but come on fella if you're gonna use a name like that at least have a go before giving up and slinging your car into a garage.
Sorry if the above was a bit strong.
318i Touring
22sas
Post Mon Dec 19, 2011 8:00 pm
sorry m8 did'nt mean to offend anyone lol but got alot of respect for the special air service m8 and yeh I know a few ex members but no not related to any and my cars in a garage cause I aint got the time with xmas and everything else.Did'nt think my user name was a big deal use it on alot of sites
22sas
Post Mon Dec 19, 2011 8:06 pm
cheer's guys for advice
redcar
Post Mon Dec 19, 2011 8:53 pm
TouringTash wrote:Forget the lead set, A few older zoners will attest that they have never seen a set fail.
Whats with your name 22sas ? ******* loose that sunshine you're taking the ******* pee pee!
When i pulled out one of the 20 year old leads of the m40 engine, it was absolutely cracked and messed up, half of it stayed on the spark plug!
Seems worth it to change the leads whilst you're changing renewing the other ignition parts
Jos
Post Thu Dec 22, 2011 3:30 pm
Yup, also had this happen, make sure you have leads to replace or transport to go get some. 1 lead is in 2 parts as the ignition pulse pickup has to go through it.
'94 e36 tree climber
Post Thu Dec 22, 2011 11:15 pm
redcar wrote:When i pulled out one of the 20 year old leads of the m40 engine, it was absolutely cracked and messed up, half of it stayed on the spark plug!
Sure these weren't already aftermarket leads. I've NEVER seen an OE E30 ignition lead that has deteriorated, although I've seen afew that are broken because of some muppet pulling the caps off of the plugs by the leads.
redcar
Post Fri Dec 23, 2011 8:45 am
They were original beru ones. They had cracked and were basically no good anymore.
Replaced with some low quality Ecp ones, couldn't find beru again
Post Fri Dec 23, 2011 9:55 am
Maybe someone in the past had regularly cleaned the engine bay with a chemical that wasn't friendly to the rubber? Or a 'bad batch' once managed to get through quality control at the factory?
I'd still recommend that anyone who definitely requires replacement leads obtains a good second hand OE set, rather than aftermarket.
redcar
Post Fri Dec 23, 2011 11:34 am
Brianmoooore wrote:Maybe someone in the past had regularly cleaned the engine bay with a chemical that wasn't friendly to the rubber? Or a 'bad batch' once managed to get through quality control at the factory?
The rubber was fine, the connectors on either end were all cracked and some broke off and remained on the spark plugs
