SPEEDO/CLOCKS LIGHTING
fekaiki
Post Mon Dec 19, 2011 9:15 am
Had problems with the lighting of my clocks since I bought the car. At night, when I switch on my headlights, my clocks didn't light up at all...After about 2 or 3 minutes of driving, my speedo and fuel gauge would light-up (guessing the left-hand side lamp was a bad connection) but the right-side of the clocks stay unlit.
After taking the whole unit out of the dashboard, a real bitch for someone unexperienced like me, I replaced bulbs etc etc and placed the clocks back in the dashboard.
For about 15 minutes, everything was illuminated as it should be, then sadly I was back to square one again. I now have to bang on the top of the dash to get the left hand side illuminated.
Not enough time/too lazy to take the clocks out again without having a good enough idea of what the problem is. I'm guessing it's bad contacts/connection?! :? :? :?
Duke137
Post Mon Dec 19, 2011 9:20 am
Sounds stupid but you know that turning the headlight switch knob brightens/dims them don't you? :?:
Post Mon Dec 19, 2011 9:38 am
There's no 'known' E30 fault that gives what you describe. An intermittent bulb on one side of the cluster only is usually a blown bulb, where the broken filament ends randomly touch, and are then held together magnetically until the power is switched off.
Are you sure you didn't refit the original bulb?
The only other possibility is that at sometime in the past, the circuit board of your cluster has been subjected to some less than expert attention, and is physically cracked.
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Dec 19, 2011 10:10 am
How about the illumination for your heater controls or the ashtray, is that working?
The interior lighting is all run from grey/red wires, so if none of them are working then it suggests some issue with the connection from the headlight switch.
If it's just the dash cluster, then the switch and wiring is fine, and it's either the plug that goes into the dash, or the dash circuitry itself.
Unfortunately if the dash is knackered you'll have to replace it. To make getting it in and out easier next time, there is a guide on the Wiki:
http://www.e30zone.net/e30zonewiki/inde ... eplacement
Post Mon Dec 19, 2011 10:45 am
Think I may have misread the OP slightly. If no illumination bulbs in the cluster light up, and the other dash/ashtray bulbs do, then check carefully where pins 23 and 24 of the white socket are soldered to the circuit board. Rough handling can crack the joints.
Grrrmachine
Post Mon Dec 19, 2011 10:59 am
Brian, do all lights earth through brown/white cables? If so, is there a dedicated brown/white earthing point that might also be affecting the cluster?
Post Mon Dec 19, 2011 1:21 pm
All the panel/instrument/switch/ash tray illumination lamps, except the one for the main lighting and fog switches are 'earthed' by this brown/white wire which goes to true earth via the rotary rheostat which is part of the main light switch.
Shorting the brown/white wire to earth will bypass the dimmer, and make the lights come on at full brightness if they are supposed to be on.
Easiest access point to the brown/white wire is at the bulb that illuminates the rear ashtray.
