windscreen wipers constantly running on slow
randomspeedfreak
Post Sun Dec 18, 2011 3:09 pm
as soon as i turn the key to the run position my windscreen wipers come on.
anyone else have this problem? any ideas?
recent m52 conversion if for some mad reason that makes a difference
Post Sun Dec 18, 2011 6:44 pm
Check in the fusebox for anything metallic that might have slid under the wiper control module.
Does this happen at the first or second key position?
randomspeedfreak
Post Sun Dec 18, 2011 7:00 pm
Brianmoooore wrote:Check in the fusebox for anything metallic that might have slid under the wiper control module.
is the wiper control module the large black relay type box?
ill go look now.
it happens only at the second position
my ews is sharing an earth with the stalk on the steering column it cant be this can it?
cheers Brian
Post Sun Dec 18, 2011 7:12 pm
ill go look now.
Yes.
Interesting - the wipers are powered up on the first position, so it might well be something you've done!
cheers Brian
I wouldn't totally rule it out. This is not a 'good' earth. The steering column is electrically insulated at the top end by the plastic washers in the 'crash protection' arrangements, and only earths via the clamp at the bottom.
