right should be an easy one,
coming to the end of my m52 conversion, just bleeding the brakes - simple enough job right? wrong!
ive got the one man eze bleed jobbie, and ive started furthest away from the master cylinder (rear offside) then done the rear left and finlly the front right.
however when i try to bleed the front left im getting a continuous stream of bubbles through as i pump the pedal, and when i let off the fluid is travelling back up into the system along with some air. now if i put the lid back on the resivoir and tighten all the nipples up, the pedal travels to the floor, working only if i pump it -it has air in it
if i retry, trying to make sure no air is allowed to run back up into the caliper i eventually get the same problem.
there is some fluid around the master cylinder area, but i think i could have a cracked line rather than an actual master cylinder problem?
where is the best place to get some lines done? or should i get some pipe and do it myself? where from?
cheers,
Matt
bleeding brakes
randomspeedfreak
e30den
You maybe doing something wrong, chuck the easy bleed thing in the bin [thats where mine went]
and get some one to pump the pedal for you under instruction should be fool proof.
randomspeedfreak
okay cheers mate, ill go back to that.now wheres the missus gonee30den wrote:You maybe doing something wrong, chuck the easy bleed thing in the bin [thats where mine went]
*edit found her shes in the kitchen
e30den
Just be sure to tighten the nipple [on the caliper] before your assistant lets the brake pedal back up.
Grrrmachine
- E30 Zone Wiki / Team Member
Seems simple to most, but here's the Wiki technique, just in case:
http://www.e30zone.net/e30zonewiki/inde ... s#Bleeding
e30den
Nice one zonerGrrrmachine wrote:Seems simple to most, but here's the Wiki technique, just in case:
randomspeedfreak
okay just rebled the brakes with a glamorous assistant.
im still getting so the first push of the pedal goes almost all the way to the floor (but not quite) then pumping gives a hard pedal after a few pumps
i recon could be a cracked line, a leak between the join at the master cylinder, or a duff master cylinder?
anyone got any ideas?
cheers,
Matt
cheers,
Matt
Leave it a day, and try again, when small air bubbles in the fluid will have joined together to make larger bubbles.
Careful with the "glamorous assistant". Many relationships have been permanently soured by brake and clutch bleeding together!
