From reading other threads it seems this can be caused by a knackered camshaft. Are there any other symptoms that would point to this definitely being the case ?
Are there any other things that might cause the constricted revs? I've read that it could be a blocked fuel filter but as it runs mainly on LPG I can't see that being the issue.
Runs fine in every other regard except for a very slow loss of coolant.
M42 for the record.
Wont rev past 3000 rpm
BEMER_LAND
Had an m40 which wouldnt rev past 4k and a whole lot of blue smoke. had some oil in the water which would mean the head gasket was gone. binned the engine but mabe thats the cause?
kilrone
have your fuel pressure tested as this is one of the most common causes
