its a 316i basically, it cranks over, spark coming through, no fuel in top hose, bottom one i assume is return pipe? there was some fuel in there, i cranked it no fuel is getting through i assume its the fuel pump?
theres about a quarter tank, obc saying 49 miles left,
im thinking it could be a relay/ fuse possibly? the car was working perfectly fine, other than i have to jump start it every day! and alternators not charging, but other than that theres no hiccuping or any hesitance from the engine, drove it yesterday was working fine, does anyone know which ones the fuel relay or any fuses hidden that might be associated are? could of blown from being jumped so much
my voltmeter has also broken so i cant check the fuel pump directly, thanks
help car has just died
markgE30
i would just go through your fuse box and replace any that have blown not sure what relay.easiest way to check the fuel pump is take the black cover off under the back seat and listen to see if it buzz's when you are turning the engine over.sometimes a little knock when turning over gives it a helping hand if its seized.sounds lyk your fuel pumps knackerd to me tho
TouringTash
Search in the wiki for the fuse designation, though it should be on the fuse lid?
If the alt isn't charging what keeps the car running?
have you done a search fuel pump, then select all terms?
Or how about just looking through he first page or two of the technical section?
318i Touring
bmw9818
nope nothing on the fuse box lid, the alt is on the way out id of thought as battery is almost allways dead even after a few hours, at night the lights go dim when im driving slow / eco driving, have to keep the revs up and the lights go bright again ?TouringTash wrote:Search in the wiki for the fuse designation, though it should be on the fuse lid?
just done a search, a few normal fuses in the fusebox relating to fuel system, checked those they seem fine, cant find the fuel relay though,
pins 30 to 87 found that, orange relay?
bmw9818
will try see if the fuel pump buzzes tomorrow, dads car battery is now also dead along with the booster pack, arrrrrrrrrgh
TouringTash
This is a joke.bmw9818 wrote:
the alt is on the way out id of thought as battery is almost allways dead even after a few hours, at night the lights go dim when im driving slow / eco driving, have to keep the revs up and the lights go bright again ?![]()
Surely no one is stupid enough to drive at night with incorrect lighting, or to put the lives of other road users and pedestrians at risk?
318i Touring
andyp
- True Old Skooler
poss the fuel pump or fuse
Grrrmachine
- E30 Zone Wiki / Team Member
get the boster packed charged and apply it directly to the pump. If that spins and chucks out fuel, then start working your way back through the electrical and fuel system.
The Wiki is a mine of info here, especially Fuel:
http://www.e30zone.net/e30zonewiki/inde ... n_Problems
bmw9818
did the wire jump trick off the relay socket, relay was at fault also, had a spare one of those, fuel pump was working but slowly, had a spare pump and swapped them over, started first turn!Grrrmachine wrote:get the boster packed charged and apply it directly to the pump. If that spins and chucks out fuel, then start working your way back through the electrical and fuel system.
sorted! cheers
