Touring tailgate window trim?
rover-2000
Post Wed Dec 14, 2011 4:08 pm
Guys
The trim strip at the bottom of the tailgate window on our touring has a one inch section missing at either end. Are there meant to be end finishing trims, is it meant to look like this or has the strip shrunk?
Many thanks
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
Cloggy Saint
Post Wed Dec 14, 2011 4:09 pm
It's shrunk! I fitted a new one to my touring in the spring and it's already about 1cm short at each end.
rover-2000
Post Wed Dec 14, 2011 4:17 pm
Thanks-I will get a new one. How do I remove/refit? Is it easy?
Kind regards
John
1989 320i Touring
Cloggy Saint
Post Wed Dec 14, 2011 4:32 pm
Just grab it at one end and pull it out, then marvel at the rust that's sitting behind it!
rover-2000
Post Wed Dec 14, 2011 4:43 pm
Does the new one just push back in?
Kind regards
John
1989 320i Touring
Cloggy Saint
Post Wed Dec 14, 2011 5:58 pm
yep, just pushes in, or in my case, falls in. I swear these strips have become smaller over the years! Push it up as tight as you can at each end to delay the inevitable shrinkage.
rover-2000
Post Wed Dec 14, 2011 6:17 pm
Thanks.
Kind regards
John
1989 320i Touring
Post Wed Dec 14, 2011 6:22 pm
If under the seal is rust free ( unlikely unfortunately ) put a good bead of black silicone sealer in the slot before refitting the strip - that removes the water-trap that is there as standard :roll:
Cloggy Saint
Post Wed Dec 14, 2011 6:45 pm
And I recommend cutting each end of the strip at an angle so it meets the side trim piece nicely, it looks much neater than just butting it up straight :wink:
