exhausts pipes 320/325
imye30
Post Wed Dec 14, 2011 11:21 am
are the down pipes down from the manifold to the rear exhaust the same on a 320/325 as i don't no weather to change just the rear box an put the 325i on or will i have to change the hole system as i am currently using a 325i engine with a 320 exhaust system best option to go down its a convertible
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Dec 14, 2011 11:59 am
Do you EVER look at the Wiki? Almost every question you ask has its answer there:
http://www.e30zone.net/e30zonewiki/inde ... aust_Pipes
Post Wed Dec 14, 2011 12:11 pm
Grrrmachine wrote:Do you EVER look at the Wiki? Almost every question you ask has its answer there:
realoem will also tell you what you need to know if you can find your way round it.
