which diff will be right
imye30
Post Mon Dec 12, 2011 5:24 pm
had a engine swap done put a 325i engine in a j reg which had a 320i engine an dont know what diff will be in this one which one will best to match up with the 325i
leeparkes
Post Mon Dec 12, 2011 5:28 pm
You should have a 4.1 small case on now if the car was a 2.0, ideal for a 325i is 3.64, 3.73 or 3.91.
Grrrmachine
E30 Zone Wiki / Team Member
3.64 for cruising, 3.91 for spirited driving, 3.73 for in between.
imye30
Post Mon Dec 12, 2011 5:34 pm
the car will only be used for cruising an to an from work an some motor way driving
leeparkes
Post Mon Dec 12, 2011 5:37 pm
3.64 then.
imye30
Post Mon Dec 12, 2011 5:49 pm
sorted need to find a good one then
imye30
Post Mon Dec 12, 2011 9:33 pm
the 3.64 will that be a lsd one
Ajsingh
Post Mon Dec 12, 2011 10:34 pm
A 3.64 can be an LSD or open. The choice is yours
An LSD will be set you back at least £250 where as an open will cost around £50 ish from the right buyer on here
E30 Crazy!
imye30
Post Tue Dec 13, 2011 5:45 pm
i gather a open diff is the standerd one
